new 22r help
new 22r help
Just bought a new not rebuilt 22r from japan engine .com was wondering do I need to pull the cam and crank bearings and lube them up with assembly lube then re torque everything just wondering if anyone has had any prob not doing this with a long block
Should be already pre lubed!
If it hasn't been pre lubed then it isn't much of an engine to start with. I would just look and see if you can see any assembly lube in there. If not then take it apart. But should be pre lubed!
buckz6319
Aug 5, 2017 03:50 AM
Toys4parts
Sep 26, 2015 01:56 PM
