Engine Swaps Swapping an engine in your Toy, here is where to learn how
89 22re put into an 87 4runner
Old 03-08-2011, 08:21 AM
bsmall505's Avatar
I recently bought a rolled 89 4runner with a 22re. I am putting the engine out of the 89 into my 87 4runner that also has a 22re. The engine swap went well. Now I am doing the wiring. The fuel injectors seem to have different plug ins. Can I just cut and splice the correct ends onto my existing harness?
Old 03-08-2011, 08:35 AM
xxxtreme22r's Avatar
no. resistances are different, just swap all of your old sensors and whatnot from the 87 motor to the 89 motor, and keep your 87 ecu.
Old 03-08-2011, 09:54 AM
bsmall505's Avatar
So I can just take the injector connectors off of the 89 and spice them into my 87 harness?
Old 03-08-2011, 10:17 AM
no, take the injectors out of the 87 and put them on the 89 along with ever other sensor from the 87 motor. IE AFM, temp sensors, Knock sensor if it has one not sure, and everything else that plugs into the wiring harness. Keep your 87 harness in the truck don't hack at it and keep the 87 ECU in there as well.
Not sur eon the TPS and the throttle body, but to be on the safe side swap those from the 87 to the 89 as well.
Old 03-08-2011, 10:37 AM
bsmall505's Avatar
Well that is more work than i wanted to do, but if thats what is best I will do it. Thanks a lot
Old 03-08-2011, 11:00 AM
Staff
DeathCougar's Avatar
The amount of work is irrelevant. Its about doing it right the first time. You need to swap all the electronics, wiring, sensors, and such from your motor onto the donor motor. Don't try cutting and splicing and messing with all that. Its super easy to just swap the parts over. The few extra minutes spent now will save you hours of headache.
Old 03-12-2011, 04:06 PM
bsmall505's Avatar
I am changing the injectors out and got an o ring and seal kit for each one. The kit only came with an o ring and seal for the rail side. Do I need to replace the seal on the other side also?
Old 03-13-2011, 07:43 AM
swampfox's Avatar
Just for future reference I made the mistake of changing the injector plugs and not the injectors, and the truck would only run with about half the normal power. This was several years ago and I now know better.
JF9243176
10-08-2017 04:21 AM
Ichneumon
09-27-2015 04:21 PM
JF9243176
06-24-2015 04:53 AM
Robinhood150
06-23-2002 05:05 PM
94 First Responder
06-06-2002 02:19 PM
Quick Reply: 89 22re put into an 87 4runner
