SAS steering rubbing and binding
Old Jun 15, 2011 | 06:54 PM
Eat_at_Joes's Avatar
Hi guys, as stated i am having problems with binding
The sas kit is from all pro and is 4"
ram is TG 6"
the biggest problem is the tie rod and drag link are interfering with each other when driver tire is stuffed into wheel well
heres some pics of my setup
(note i did not do this swap and the shop dont know beans from dirt)
If anyone has any ideas or suggestions let me know. if nothing else i might just load it and take it to scotty at addicted offroad
Old Jun 15, 2011 | 07:17 PM
waskillywabbit's Avatar
Take a better pic of the IFS steering box. Looks like it needs a frame reinforcement kit and moved forward.
You need proper ubolt flip plates.
:wabbit2:
Old Jun 15, 2011 | 07:59 PM
whats wrong with the flip kit, thats the one that came with the kit unless the shop screwed me more than i thought
Old Jun 15, 2011 | 10:20 PM
dropzone's Avatar
Fossilized
like wabbit said...the steering box needs to go forward
Originally Posted by waskillywabbit
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
what you don't want to have happen when you install your high steer:
Originally Posted by 98taco4x
oh and make sure that your drag link clears your tierod.
Cause you don't want this.
Old Jun 16, 2011 | 04:06 AM
Your u bolt plates are just flat plates, no bends on the end to prevent the plates from cupping with the u bolts.
:wabbit2:
Old Jun 19, 2011 | 08:11 PM
ScottyC's Avatar
FWIW, those are All-Pro u-bolt plates. They are fine.
I agree that the steering box just needs to be relocated forward. I know we've talked a couple times already, so give me a call. We can fix the issue and move it forward for you.
Old Jun 19, 2011 | 08:21 PM
scuba's Avatar
I've had the same allpro u bolt flip plates on my rear end for the past 2 years and they are fine.
Just my 2 cents.
Old Jun 19, 2011 | 08:33 PM
im glad to here that.
anyone have input on the ram? the last couple of times i wheeled, the ram has rotated around the tie rod and i have to stop, loosen, turn, then re-clamp the ram
Old Jun 20, 2011 | 05:00 AM
I've had 2 AP kits and never seen u bolt plates like those. All mine were bent up on the end and thinner.
Tack welds.
:wabbit2:
1uzRunner
63
Nov 10, 2018 03:58 PM
punks_is_4x4
May 31, 2016 06:03 AM
seab1209
Sep 3, 2015 05:41 PM
128keaton
Sep 3, 2015 05:09 PM
dguzzi
Sep 3, 2015 08:48 AM
