Removing a leaf from the pack
Recently finished SAS on my 88 4runner and the front is a few inches higher than the rear. I have the trail gear 5'' hd springs in the front and 5'' in the rear, but it is no where level. I was just wandering if I removed a leaf from the front pack if it would drop the front enough? If so which one should I remove?
Might contact TG for advice, but generally pull the 2nd leaf from the bottom and see how it looks. Also, most folks gor with 1" lower spring up front since you get a built in 1" of lift due to the spring hanger and longer shackle on a SAS.
Jcrawl94
10
Oct 24, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
