Please advise! Rear lift suggestions?!
Old Nov 28, 2013 | 07:42 AM
RaunchBox's Avatar
Hello all! I have recently "finished" with my SAS on my 1990 4runner. I tried to keep it as low as possible, and as you can see in the pics, it is a bit more high in the front than the rear...
This bothers me a lot. I am looking to raise the rear, however I already have 3" springs (new) on the rear of the truck in the pictures... So, my question is, what the hell do I do to get the rear up to match the front? I know I can do a leaf swap, but dont really want to do that right now.. maybe down the road when I decide to go full retard and make it huge... for now, I want the rear to just match the front using the coil setup.
Any suggestions on how to accomplish this? The current springs I have on there are Pro-comp 3".
Thank you all for your help!!! Happy Thanksgiving!
Old Nov 28, 2013 | 07:46 AM
RaunchBox's Avatar
Old Nov 29, 2013 | 06:23 PM
JonnyBoy's Avatar
I believe the options are rear fj80 lift springs instead of stock fj80 springs, which will already lift the rear 3 1/2" to 4", or redo the link setup in the rear and go with coil overs. Leafs end up being cheaper and easier to figure out, hence why it's the most popular solution.
Old Dec 3, 2013 | 10:33 AM
Teuf's Avatar
I too had 3" springs when I did my SAS. Rear was low. I added 6" shackles, 1 inch block and some flat leafs.Name:  2013-07-15172838_2_zps98c7ac83.jpg
It still sits a half inch high in the front. But it will settle. And or i can add leaf or 2 more in the back.
If you need the height just get the 4" trail gear springs and be done with it.
Old Dec 4, 2013 | 07:32 AM
RaunchBox's Avatar
I have coils in the rear tho... not leafs yet
Old Dec 4, 2013 | 09:06 PM
little_twin's Avatar
Coil spacers can be had cheap, but are far from ideal.
Old Dec 5, 2013 | 01:45 AM
91 4Runner's Avatar
He already has lift coils in the back.
How much too low is the rear? This might help with the replies.
Old Dec 5, 2013 | 02:00 AM
dropzone's Avatar
Fossilized
Convert your 4Runner to rear Leafs...
Old Dec 5, 2013 | 09:34 AM
Believe it or not, much like lift blocks, coil spacers are available in different thicknesses. Cheap way to go would be to buy thicker spacers, best would be leaf swap or improve the 4 link and add coil overs.
Old Dec 5, 2013 | 09:38 AM
driveshafter's Avatar
blocks
put blocks on
Old Dec 5, 2013 | 09:41 AM
highonpottery's Avatar
get lift springs with a different spring rate, or taller springs, like 4". also, wait for your front leafs to settle in if you just finished the SAS
Old Dec 20, 2013 | 11:22 AM
jtinco's Avatar
When I lifted my 94 I had the same problem. I ended up using a metal spacer (I think it was from All Pro) which got me level. I hate using spacers but it worked really well and with the spring length/rate the truck drove and handled great and I could still stuff the rear axle into the stops.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
akaphilly
Jul 9, 2015 02:18 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
