Need Help With Sas?
Old Aug 7, 2008 | 08:58 AM
90_4runner's Avatar
Need Help With Sas?
well i got a 1976 landcrusier axle and when im gonna put the TG high steer arm on the knuckle i found out that the hole for the TG r not as narrow as the Landcrusier. But the LC axle already had a custom High steer on it too so i guess i might have to use the Custom high steer instead, but it doesn't have another hole for the cross arm from the steering box to the custom high steer. wat should i do? weld a bracket that has a hole for the cross or wat else?
Old Aug 7, 2008 | 09:37 AM
waskillywabbit's Avatar
You have to swap the mini truck knuckles onto the LCA axle to use the mini truck stuff IIRC.
Old Aug 7, 2008 | 11:55 PM
90_4runner's Avatar
oh ok kool then i might as well do that then buy another 79-85 axle. Thanks u very much
Old Aug 25, 2008 | 10:32 AM
netwt12's Avatar
as wabbit said you'll have to swap the mini-truck knuckles onto the lc axle to use the trail gear highsteer. unless you already have the mini-truck knuckles you might look at trail gear's six shooter knuckles.
Old Sep 11, 2008 | 09:13 PM
90_4runner's Avatar
i already traded my LC axles to a mini axle.
RickyD
Oct 2, 2015 07:53 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
Flying91
Sep 10, 2015 03:41 PM
