Midnight 92 SAS
Old Oct 9, 2016 | 06:08 PM
Flippz's Avatar
congrats on the new house for the axle, but it belongs under the truck.lol Got mine started and it is slow going waiting on every thing. I went with the tg 4" kit as this is my first ever build of any thing like this. I am a bit intimidated by this and I have to go at it alone as most of my friends cant change a tire. good luck and measure 3 times and tac then remeasure. I am gonna start the cutting on the 92 tues or weds. waiting on the welder to get here.
good luck and I like the flag over the axle. corp to the core
Old Oct 11, 2016 | 02:32 PM
Back to the Future's Avatar
Got those rotted tires and rusty old wagon wheels off.
Right knuckle ball close up.
Left knuckle ball close up.
Slow steady progress...
Old Oct 11, 2016 | 04:14 PM
ZUK's Avatar
ZUK
wow, that one needs a power sprayer.......
Old Oct 11, 2016 | 05:15 PM
Haha...it does indeed. Good thing I happen to have one.
Old Oct 30, 2016 | 06:15 PM
  #25
Gizler00's Avatar
X2 on Eds advice. Always tack or clamp the front Hanger until you can get some weight on it. Or on the ground at least. Welding the front Hanger is usually one of the last things that I do.
Cant wait to see the axle all cleaned up.
Old Dec 4, 2016 | 08:38 PM
  #26
ChinkTruck's Avatar
Here's a tip for your pitted knuckle balls, a little pitting probably wont be a big deal but your pic looks like it may be "grooved" like my axle was. Clean them up best you can with a wire wheel then resurface them with JB Weld. Mine were as bad or worse than yours. One side had the trunion bearings completely blown which allowed the knuckles to carve a groove in the ball.
Heres the after result
It sounds hillbilly and hokey rigged but the trunions support all the load, the balls just act as a sealing surface to keep grease in and water out. After wire wheel clean them real good with alcohol or the like before applying the JB. Use emery cloth to smooth and round the hardened JB weld. Good luck, Hope this helps.
Old Dec 30, 2016 | 04:23 AM
  #27
Thanks! It's not hillbilly at all. I have read about the JB Weld on the knuckle balls quite a bit and I planned on doing it. This axle wasn't taken care of so I knew I had my work cut out for me from the very beginning. Nothing a little patience and a lot of research here on the ol' Yotatech won't get me through.
Old Jan 4, 2017 | 09:21 AM
  #28
wberry85's Avatar
Glad to see you finally making the plunge!
I would suggest you buy the biggest welder you can afford. You NEED to be able to weld 1/4". I did mine on a 220v Lincoln 170. On many sections I had it cranked all the way up. I am paranoid but I did not want to be busting welds on the trail. There are tricks you can use like root passes and preheating etc but if you dont have a competent welder working with you I would go bigger than you need to guarantee your penetration is on point! I am not saying the Hobart 140 cant do it but just be double sure before you close the deal.
Building the axle was my favorite part. Try and find a place to buy grinding discs in bulk....youre gonna need em lol.
Old Feb 24, 2018 | 01:03 PM
  #29
Finally decided to get after it and get this sucker broke down for the rebuild.
Surgery has begun.
So I didn't notice it before but I think the perches had already been cut off and re-welded on.
Looks like stock axles.
Old Feb 24, 2018 | 02:32 PM
  #30
muddpigg's Avatar
Like the JB weld trick. Mine are pitted too.
Old Mar 11, 2018 | 11:54 AM
  #31
1/2" steering stabilizer bracket that was on there...PITA to cut off.
Old Jul 31, 2018 | 06:40 PM
  #32
Yopar's Avatar
Any updates? Would love to see how things are going.
Old Jul 31, 2018 | 07:13 PM
  #33
ZUK's Avatar
ZUK
Me too
Old Aug 12, 2018 | 01:10 PM
  #34
Unfortunately no....current focus is to replace my air conditioning so I can actually drive the truck regularly. Summers here are horrible.
Old Sep 12, 2018 | 05:04 PM
  #35
zytra's Avatar
Heya,
So much in common =]
Got my axle in 09/16 and procrastinated 2 years before getting started on the started.
Funny fact, I fixed my A/C yesterday haha; well it only needed a refill - The compressor wasn't starting but that was because of the refrigerant pressure switch which I had no idea existed (compressor won't start if the refrigerant pressure is too low).
Good luck!
Old Sep 12, 2018 | 05:52 PM
  #36
Originally Posted by zytra
Heya,
Good luck!
Seems like it is taking forever but to be honest life happens sometimes. I have the axle and when the time is right the SAS will too. Being in the military makes it challenging to balance time with my family when I am home so I'll get to it. Hell, I enjoy any wrenching I get to do doesn't matter what it is.
Old Sep 13, 2018 | 09:33 AM
  #37
YOUNGIAM's Avatar
GET R DONE!!! Following.
Old Nov 1, 2020 | 05:06 PM
  #38
Been trying to clean it up before I disassemble the right side. As you can see this thing was neglected for a LOOOOONNGG time. Not to worry though. We'll get er' done right.
Old Nov 1, 2020 | 07:15 PM
  #39
ZUK's Avatar
ZUK
That could take years............................................. .........
Old Nov 2, 2020 | 05:07 AM
  #40
It was REALLY bad. I have hit it with degreaser multiple times, scraped off the grease and grime, and repeated.
rod1210
Feb 9, 2017 04:10 PM
dbbowen
Apr 15, 2016 11:08 AM
ryan13
Engine Swaps
Mar 16, 2016 06:49 AM
leviathan278
Feb 26, 2016 12:02 PM
BUDD
Feb 8, 2016 12:53 AM
