Longfield 5th stud kit
Anyone have any exprience the 5th stud high steer trunion bolt setup from Bobby Longfield? It's near the bottom of the page here:
http://www.longfieldsuperaxles.com/
I have an SAS'ed 88 truck that I bought already built. Looks to have the Trail gear 4" SAS kit with the 4 bolt high steer kit that's included. I see lots of failures from guys on here, and am looking for a relatively quick and cheap way to fix that weak link.
I broke a ton of knuckles and studs of the years. I wouldnt think that little tab would be a fix all. For 50 bucks you can make something nicer and stronger.
FWIW
Stock studs and knuckles I sheared studs off...
Stock knuckels ARP studs I broke the knuckles or the trunion bearings...
FWIW
FWIW
FWIW
Most of the time when studs break its because they arent torqued properly. It's hard to remember all the time before every run. The 5th stud is just cheap insurance. Make your own man....its a danged piece of angle iron and a BOLT....good luck and keep those studs tight!
By far the best thing I did
Never had a problem with a steering arm stud since I went chromoly and six shooters.
Never had a problem before either.
Axle was just kinda in, nothing was tightened just snugged. IIRC they hit the welds a bit and I ground the weld down a bit.
I had issue's with knuckles, studs, birfs and gearsets. I wheeled with people that had trunion bearings blow apart, highsteer arms break the pins off ect. This was the most logical and cheapest fix for me. I have less into my 60 than I did my toy axle and some 6 shooters and can still upgrade. For me it was the right choice.
RyanJ989
11
Apr 7, 2021 09:41 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
justdifferentials
Sep 5, 2015 06:52 PM
