Help i screwed up!!!!!
Old Nov 17, 2009 | 08:40 PM
augdog45's Avatar
ok so I am doing a sas on my wifes 87 runner and I was using the template to punch the holes for the sleeves that go under the body mount. well I am kinda new at this and like a complete retard I failed to tack-weld this stuff and check for proper fitment. So I welded the living out of everything! well I was a little bit off. about a half in off. damm I suck. so what should I do? also it looks like the rig leans a little to the right. and what size spring should I run in the rear to level her out?
Old Nov 17, 2009 | 09:16 PM
muddpigg's Avatar
Damn, stop working on your wifes rig.
Old Nov 17, 2009 | 09:17 PM
pitster33's Avatar
order a new sleeve and jig. Then grind the old sleeve that's off out and plate both sides of the frame and start over. What kit and springs did you use in the front because that's what going to tell us what rear kit you need to level it out.
TheBFA
Feb 15, 2020 06:55 AM
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
