help carrier setup
Old Jan 6, 2011 | 04:57 AM
blake.nemitz's Avatar
help carrier setup
hey guys i am going to put a high pinion diff in the front axle on my sas'd runner. question is i can get a housing for next to nothing, now will a 4cyl carrier fit in there or should i use my rear v6 carrier in the hp diff and lock the rear. need to know what carrier will fit in there thanks guys
Old Jan 6, 2011 | 05:01 AM
new gears will also be installed just need to know what carrier will fit the hp diff
Old Jan 6, 2011 | 05:17 AM
dropzone's Avatar
Fossilized
i would check out Zuk's site: http://gearinstalls.com/
he isn't doing set ups any more but I bet he would be willing to answer a PM.
Old Jan 12, 2011 | 07:34 PM
FourGee6Tee3's Avatar
A 4cyl carrier will not work. You can use a v6/turbo carrier.
Old Jan 12, 2011 | 08:43 PM
peow130's Avatar
Idk where you heard that.
A 4 cylinder carrier was found stock in the front of all solid axle rigs from 79-85..
the 6 cyl carrier is just stronger, so it's preferred.
Old Jan 13, 2011 | 02:51 AM
91diesel's Avatar
the high pinion front is a V6/turbo setup though, not a 4cy. They also have thier own (not run of the mill V6) gear sets because they are reverse cut gears. I know factory 4.10's are available and aftermarket 4.88's and probably a 5.xx.
Old Jan 13, 2011 | 05:35 AM
thanks guys trail gear has a locker conversion for the hp diff with gears so im going to use that with a v6 carrier in a new housing. going to be SWEET!
Old Jan 13, 2011 | 05:52 AM
waskillywabbit's Avatar
You need to buy it from me and use your discount!
:wabbit2:
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
4runnerFireman
Sep 29, 2015 06:24 AM
Keithstoyota
Sep 27, 2015 07:29 AM
