DTB project SAS 93 xtra cab
Old Mar 11, 2007 | 03:07 PM
dirtoyboy's Avatar
here's my starting point.... 93 xtra cab with over 300k. ex daily driver, flatbed, new engine, 4.88's and detroit and some other stuff
spray painted it. i thought it turned out pretty good
84 axle
Sky truss
Sky diff guards (front and rear)
Marlin knuckle ball gusset kit
OEM knuckle service
Hy-steer (Marlin)
ARP knuckle studs
hydro assist, make new reservoir
Stock third
precision gear 5.29s
Open until I can afford longs and an aussie locker
Springs Marlin 4" USA
Bilstein s
Sky shock hoops
Marlin spring hangar
some other crap
Triple drilled flanges
Breathers (nissan, homemade)
u-bolt flip (Marlin)
wheel spacers
ifs calipers and fj60 rotors
Marlin rear kit
Power steering box mount plate (Marlin)
36x12.5 SX's
traded my IFS for this>>>
what a greasy mess that was! whew!
Old Mar 11, 2007 | 03:14 PM
dirtoyboy's Avatar
OEM knuckle service ( i dont trust those ˟˟˟˟in chinese bearings on my truck)
knuckles cleaned up nice too
mmmm......burning metal lol ..welding caps on the steering stops
lasers are cool lol
bzzzzzzzzzzzzzz
please feel free to critique welds
Old Mar 11, 2007 | 03:17 PM
dirtoyboy's Avatar
sloooow progress
IFS where it belongs lol
mmmm tasty
more later this week...let me know what u guys think
Old Mar 11, 2007 | 04:14 PM
AxleIke's Avatar
looks nice.
How is the rattle can job holding up as far as paint chipping, etc...
I'm glad to see i'm not the only one with car crap scattered throughout the house
Old Mar 11, 2007 | 04:50 PM
dirtoyboy's Avatar
Originally Posted by AxleIke
looks nice.
paint is holding up ok. its krylon ultra flat i bought at walmart. im constantly touching it up from ongoing trail damage so i aint too worried about it lol. yea my whole house smells like new rubber and grease and burning metal! i live by myself obviously! haha
Old Mar 11, 2007 | 04:57 PM
881stGenRunner's Avatar
nice man, looks to be a good build. I like the truss that you put on there, that is pretty cool!
Old Mar 11, 2007 | 05:28 PM
Elton's Avatar
lookin sweet
Old Mar 18, 2007 | 05:33 PM
dirtoyboy's Avatar
lo profile drain plugs
shocks
cutting frame holes (not fun) the gussets on the outside passenger framerail were PITA's!!!
this helped a little bit
shackle angle looks good right?
Old Mar 18, 2007 | 05:34 PM
dirtoyboy's Avatar
bling bling
spring hangar tacked in place. started with 3/4 inch forward. the gussets are not welded in the picture
15 lb tank mmmmmm
I built a set of breathers for 12 dollars each. 5.00 for the fitting, 2 dollars for the filter and 5 dollars for the hose. These Nissan fittings are pretty sweet. Im gonna weld a small piece of round tube on top to protect it from breaking off.
Old Mar 19, 2007 | 01:09 AM
4RunnerKid's Avatar
looks good. i would probably mount the hanger flush and get the shackles kicked back a little more. i know TG strongly recommends having a near vertical shackle angle, but having them kicked back a little is going to give you a nicer ride, and should allow more droop out of the springs. to each his own though. with the marlin USAs, you should definitely be able to flush-mount the hanger w/no problems... are you 4 cyl or V6?
Old Mar 19, 2007 | 01:55 PM
dirtoyboy's Avatar
i have a 4 cylinder...the hangar is now mounted flush...originally i started 3/4 inch forward and it was too far. i havent cycled the suspension or settled springs at all yet...im thinking the angle will be better
Old Mar 20, 2007 | 12:16 PM
Napoleon047's Avatar
looks like you are making some good progress. shave the drain plugs completely off the axle. the low profile ones are OK for a while, but they will still get loosened by rocks and such.
Old Mar 22, 2007 | 03:47 PM
dirtoyboy's Avatar
thanks for the comments.... these are some 34.5s i had sitting around...havnet mounted the 36's yet
got her back on two of her feet lol.. i guess im halfway done :woohoo:
Old Mar 30, 2007 | 02:33 PM
dirtoyboy's Avatar
Got her on 4 wheels today...36's mounted too. just some minor adjustments needed with the rear shackle hangar. started ripping out AC and prepping front grill for the hydro cooler.
got the brakes squared away
Old Apr 2, 2007 | 02:19 PM
dirtoyboy's Avatar
To Do List
Tap steering box
Mount tabs for ram on tie rod and axle
Mount shock hoops
Bumpstops
Move P.S. box and bleed
Final weld on rear spring hangars and perches
Bleed brakes
Mount CO2 setup
Weld 2 P.S. reservoirs together
mount hydro cooler unit
Remove AC
double check torque on all critical bolts
mount driveshafts
got a little work done this morning...... :flamer:
Old Apr 2, 2007 | 02:35 PM
UKMyers's Avatar
Awesome! Which proportioning Valve did you use and did you have any issues with the metric to standard fittings? I been thinking of getting the wilwood valve but it looks like a pain dealing with the standard fittings.
Old Apr 2, 2007 | 05:18 PM
dirtoyboy's Avatar
i just ordered the kit with the fittings from front range. if i had more time i would just track down the fittings myself and order valve from summit to save some cash. This build up is hard for me now (to find time) I'm in my last semester for 2 degrees and I manage a hotel full-time.
Old Apr 7, 2007 | 06:51 PM
dirtoyboy's Avatar
mounting the power steering box......looks pretty good right?
Pitman-to-frame clearance
Old May 5, 2007 | 03:12 PM
dirtoyboy's Avatar
replace the rear crossmember which was rusted thru.....sleeved it with 1 5/8 DOM
cut off the original gas tank bracket
welded onto new crossmember
welding ram tab on tie rod
ALMOST THERE! waiting on driveshafts and I need to rebuild my power steering box
Old May 5, 2007 | 04:31 PM
yotasavg's Avatar
looks way beautiful man. i'm so envious. maybe after college...great work
