DTB project SAS 93 xtra cab
Old Apr 22, 2008 | 06:16 AM
  #41
dirtoyboy's Avatar
Originally Posted by ArkieToy
Cough Cough "FJ-40"
HA! yea thats what I meant! I always mix them up for some reason...hehehe
Old Apr 22, 2008 | 06:19 AM
  #42
dirtoyboy's Avatar
Originally Posted by 4runnerguy
hey what did u use to paint the floor of your truck dirtoyboy
Its a product called Durabak. You can order it online. It's an industrial non-slip coating. Similar to a Herculiner product but industrial grade. Works good. Dont get it on your hootus. From my research its the best bang for the buck...
http://www.nonslipcoating.com/
Old Apr 30, 2008 | 04:59 AM
  #43
dirtoyboy's Avatar
I got the axle all shaved last night..Ripping that plug out this weekend really pissed me off and I don't want it to ever happen again.....This was waaaaay easier than I thought it was gonna be...the hardest part is disconnecting the axle from the truck. I used 1/4" steel and left a little over 1/8 inch clearance on the ring gear.
..heres some pics.....
The victim>>>
Rough cut
The edges of the plate are beveled (as well as the cut in the housing) so that the weld fills in correctly giving it a nice flush fit
Looks like it should fit right?
Old Apr 30, 2008 | 05:35 AM
  #44
dirtoyboy's Avatar
Final product>>
Old May 7, 2008 | 05:28 AM
  #45
dirtoyboy's Avatar
Eh, so I keep discovering broken parts upon dis/re assembly...... The total damage report is: stripped drainplug, stripped ARP studs out of knuckle, 2 wasted trunions and 2 wasted TREs
Heres some random pics for the masses>>
I trimmed off the bottom "perch"/rock anchor
Camera doesnt focus close up very well
Some sexy new seals...thanks Marlin
I picked up this Kustom seal driver kit from Fontucky Fab....thanks Peps! :clap:
I replaced the bottom 2 studs with button head bolts since they are the first thing to hit the rocks now....
Here is the offending drain plug....
I decided to compromise with the magnet and use a drain plug/magnet on the fill plug...maybe it will slosh the gear oil up on it and metal will stick...who knows?
Old May 7, 2008 | 10:30 AM
  #46
881stGenRunner's Avatar
how are you going to drain your diff now?
Old May 7, 2008 | 11:05 AM
  #47
dirtoyboy's Avatar
I knew I forgot something!
just kidding.....The bottom two studs were replaced with button heads.....simply remove those two bolts and it drains out.....
Old May 7, 2008 | 11:17 AM
  #48
dirtoyboy's Avatar
Forgot I added this at some point....Downey header with a Flowmaster Hushpower....and I built a new rear shock tower
Sounds cherry!
Also added a rock camera
and some LED rock lites
Old May 7, 2008 | 01:19 PM
  #49
Redeyejedi's Avatar
nice work!!
Old May 7, 2008 | 03:10 PM
  #50
gotcha. Now i see how you are gonna do it. Awesome fabrication. Your doing a great job.
Old Jun 1, 2008 | 06:59 AM
  #51
dirtoyboy's Avatar
Toymin8er and I took her out for a little testing...everything works awesome except I decided I need a front locker BAAAAD....OR hurry up and build a winch bumper lol...
Fun little trail...I got stopped at the top..no locker in the front
Old Jun 3, 2008 | 06:16 PM
  #52
KODE's Avatar
nice!! so you got 4" marlin long travel springs all around?? looks like it flexes comfortably!
Old Jun 4, 2008 | 06:42 AM
  #53
dirtoyboy's Avatar
Yes....and I am verrrrry happy with them...talk about stout....the rear springs weigh like 75 pounds each and are 9 leaf packs with an anti wrap....
I am still breaking them in after probably 8-10 hard runs
Old Jun 4, 2008 | 02:46 PM
  #54
KODE's Avatar
NICE! i do you know if theres a difference between marlin springs and allpro or trailgear springs? i know they have almost the exact same kits but i was wondering about the quality...
Old Jun 5, 2008 | 04:37 AM
  #55
dirtoyboy's Avatar
From what I understand Marlins US springs and All pros come from the same manufacturer: Betts Spring Company. They are made from US steel and assembled into packs in Indonesia (I believe).... Trail gears arent bad from what I have seen.....the first few batches seem to have had sagging/bending problems but for the most part "from what I have heard" this has been corrected.
Sky Manufacturing now offers springs as well. Sky told me that they are manufactured by a company called Portland Spring Company. I dont know much else about them though...
Old Aug 3, 2008 | 04:24 AM
  #56
dirtoyboy's Avatar
a quick video of some full throttle sloppy hill assaults....didnt make it up....need a front locker!
http://i111.photobucket.com/player.s...nkedjuly08.flv
Old Aug 4, 2008 | 10:26 AM
  #57
Stomis's Avatar
drool at that trail...
Old Aug 23, 2008 | 07:47 AM
  #58
dirtoyboy's Avatar
So I finally started building a bumper yesterday...hope to finish it up this afternooon! It doesnt look like much now but its gonna be sweet. I'm using a combination of 1 3/4, 1½ and 1" DOM tubing. The winch plate is a trail gear one because i got lazy but whatever....I've had it sitting around forever.
The springs settled in nice and level now
Nice clean slate to work with
These are the cappers for the ends of the tube
Old Aug 23, 2008 | 07:48 AM
  #59
dirtoyboy's Avatar
While we are on the subject of trail gear parts check out the ears on this trail gear long spline section....see anything wrong here? btw..this is not mine...its a friends
Old Aug 23, 2008 | 10:00 AM
  #60
waskillywabbit's Avatar
Left ear looks tapered at the top (thinner).
