D44's Front and Rear
Old Feb 23, 2007 | 03:40 PM
SuperBlue's Avatar
My buddy is upgrading his CJ axles and offering his dana 44 front and rear axles to me. The only cost is I need to drive my lazy butt over to tampa for the install. He said I should install front and rear, since they are the same width and have same gear ratio's.
My original plan was to wait around for a good Toy SFA to magically show up, but no such luck down here. I wanted to stay toyota for the simplicity of interchangable parts, and I know the dana's will become a headache. I've read so many threads, here and especially pirate4x4 thinking about the dana route, the good and bad, but is it worth it in the end?
Should I pass them up or give it a shot?
Old Feb 23, 2007 | 04:55 PM
rockota's Avatar
wait for a toy. Unless you plan to convert to 5-lug, cobble together steering, change your front spring width to 27.5" on center rather than 29", etc
Old Feb 23, 2007 | 04:59 PM
95RunnerSR5's Avatar
for no cost?? are you kiddin...do it now!
Old Feb 24, 2007 | 12:51 PM
hamstrungtaco's Avatar
those cj axles are probably shorter width than toyota axles, i wouldnt waste ur time on those unless u want to put them underneath a volkswagon beatle or a minicooper. just get a toyota axle
Old Feb 25, 2007 | 05:41 PM
SuperBlue's Avatar
The axles are not stock CJ. We picked them up a year ago in Daytona for $100, a killer deal from some weird dudes. Pretty sure they were from a truck.
This is how I see the situation:
Buy a toy axle (not cheap down here), fits with minimal fabbing, same joints, all toyota parts etc...
Use FREE D44's, fits, but with a lot of modification, headaches with driveshafts, mixing domestic parts headaches etc...
I'm leaning towards the dana's since I already have them, and I can't find an afffordable stock Toy SFA. The 'FREE' is what's really attracting me. The money i'm not spending on buying a axle could be used to beef up the D44's. Junkyards are charging ridiculous prices around here, and i'd rather pick one up locally (than shipped from far away) so I can inspect it.
I'll probably go through with the dana's, but i'm kinda waiting for a seasoned SAS'er to chime in. What would you do given the situation?
Old Feb 25, 2007 | 06:50 PM
Stomis's Avatar
If your friend has the knwoledge to hook up the steering I say go for it. Any SFA is better than an IFS Plus FREE!
Old Feb 25, 2007 | 09:20 PM
what i would do then since you dont know what type of axles they are, i would try and get the Bill of Material# that should be on the ring gear and goto the dana site and look up what model those axles went to, so u can get the right parts for them, for all i know they could be closed knuckle from an f150 or they could be off of a wagoneer
heres some info
http://www.norcalttora.com/~dick/Dana%20Axle%20Stuff/
BOM#
http://www2.dana.com/expert/wc.dll?cvsp~Deabill~
Old Mar 5, 2007 | 02:32 PM
Anubiscougar's Avatar
sent you a PM superblue
Old Mar 6, 2007 | 08:22 AM
4Crawler's Avatar
Also, you should check which side the front axle differential is on. Needs to be on the passenger side.
Old Mar 11, 2007 | 02:06 PM
Down with IFS's Avatar
if the spring pads are 31.5" on the front axle, odds are it's off of a chevy truck. If they are 32" then it's probably a dodge. Sky manufacturing makes a kit to fit a chevy passenger side front axle on a toyota. 4wheel and offroad's fred williams put this on his "clampy" toyota and absolutely loves it. There's an article on the web on the install and testing.
Old Mar 17, 2007 | 06:49 AM
SuperBlue's Avatar
Thanks for the advice and tips guys.
I've laid off this thread for a while to do a lot of research. I'm pretty sure we're going through with this. I'm heading to Tampa tonight to go see my buddy, and get some plans down on paper. Unfortunately, my P/S is still fubared, so I'll have to take my car.
Hopefully soon I can start a build-up thread, instead of a questions thread.
*Sunday night, back home*
Well I now know they are Jeep axles from a Jeep J10. Plan so far is stock toy drivetrain, a mild lift (flanging out the srpings to fit the axle, decided to keep the length), and some big tires.
I'll be back with a buildup thread pretty soon. If my wife and I can get a house before then, hopefully this will happen sooner, but we are shooting for this summer)
Old May 23, 2007 | 02:01 AM
Grizz1's Avatar
First is their realy anything wrong with the axle in the truck now??? If not wait. But as for the Dana hold on th them build them for a later install or trading stock.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
