Couple of 80 axles in a 4runner and pickup
Old Oct 5, 2010 | 01:19 PM
AK/MTBOWSER's Avatar
Here are are couple of rigs I helped buddies out with. I'm a cruiser guy so I have piles of 80 parts. So I helped out some buddies with putting 80 parts into their rigs. both rigs where built on weekends out at my shop. turned out pretty well and was relatively cheap because we used a lot of stock 80 parts.
88 4runner 80 HP e-locker up front and 4runner e-locker rear. Currently has 22RE and W56 but a 3.4L and a R151 are sitting in the shop just waiting for some spare time.
Attached Thumbnails Couple of 80 axles in a 4runner and pickup-pa040046.png   Couple of 80 axles in a 4runner and pickup-pa040047.png   Couple of 80 axles in a 4runner and pickup-pa040082.png
Old Oct 5, 2010 | 01:21 PM
86 extra cab Pair of 80 e lockers. 3.4L with R150
Attached Thumbnails Couple of 80 axles in a 4runner and pickup-p8170115.jpg.png   Couple of 80 axles in a 4runner and pickup-p8170117.jpg.png   Couple of 80 axles in a 4runner and pickup-p8170119.jpg.png
Old Oct 5, 2010 | 01:28 PM
dropzone's Avatar
Fossilized
Cool set up, but that side mounted ladder would be a PITA
what part of AK? I was stationed at Ft. Rich for 4 years and have missed it every since I left
Old Oct 5, 2010 | 02:30 PM
Kenai Peninsula.
Old Oct 6, 2010 | 06:37 AM
DanKRunner's Avatar
Did you run the stock style 80seris suspension? It looks like there are coils and the stock 80 lower links.
Old Oct 6, 2010 | 07:26 AM
Yes. Used stock 80 coils, radius arms, panhard, forward swing steering box, shock towers, tie rod, drag link, etc. Just cut everything off of the 80 frame and made it work on the 4runner and mini truck frames. Frame widths in the front are actually very close. Caster is a little off but we will be putting some caster correction in them in the near future. Main reason for using the stock 80 stuff was to save some cash. I frames and things sitting so it is much easier to source the parts. Also I don't think they will have a problem with breakage in the front end since their rigs are so much lighter than a 80. Birf's and things are all a little beefier than mini truck axle's. Although not in the pic's we used IFS hubs with the longfield inner gear so they have locking hubs up front.
Old Jan 12, 2011 | 06:53 AM
riddarunner's Avatar
Thats really cool i might be doing the same to my truck do you have any pictures of the coil mount to the frame and radius arm to the frame or could you describe how you did it. Did you use the balistic adjustable mounts?
Old Jan 12, 2011 | 07:43 AM
RBX's Avatar
RBX
^^^ yes, we need more details and PICS...PLEASE!!
Old Jan 18, 2011 | 03:05 PM
ttrmike's Avatar
I like the low ride height, and those coils probably ride real nice on the road.
Is the front noticably wider than the rear now?
6th Gear
19
Dec 10, 2019 07:31 AM
Iceman4193
Jun 28, 2015 10:30 AM
zytra
Jun 24, 2015 08:14 AM
infinityisfive
Jun 16, 2015 06:51 PM
