Anyone heard of JB Weld on knuckle ball pitting?
Old Dec 26, 2008 | 03:06 PM
toyospearo's Avatar
I did a reasonable search on the subject and I can't seem to find any info.
I read a while back it was possible to fill the pitting on the outside of a solid axle knuckle ball to smooth it out.
If there is a write up or link to this procedure would you kindly pass it along?
thanks
Old Dec 26, 2008 | 03:52 PM
4Crawler's Avatar
Clean the surface, apply the filler, smooth it out and let cure. Sand smooth and you are done. You could probably find a link to auto body filler application, same basic idea.
Old Dec 26, 2008 | 07:48 PM
toyospearo's Avatar
I actually am in the process of doing it. The JB Weld doesn't seem to be setting up. It is still very tacky and it has been more than 6 hours. It is wet and humid here and that may have something to do with it. I will see what happens in the morning.
Thanks for the response!
Old Dec 26, 2008 | 07:50 PM
tc's Avatar
tc
Sounds like you didn't use enough hardener or your hardener went bad.
Old Dec 26, 2008 | 08:40 PM
86Toyrunna's Avatar
yea i always mix jb and bondo slightly hot (more hardner) also with jb weld i like to put it under a red heat lamp to cure. im interested on how it turns out, iv been pondering on how to fix the pitting on mine next time i reseal...or get longfields
Old Dec 26, 2008 | 08:48 PM
toyospearo's Avatar
I went out in the freezing rain and scraped off what I applied earlier.
The JB Weld I was using is at least 10 years old and wasn't curing. I figure the hardener is shot and it would be better to start from new.
I will post up a few pics of the process in a few days.
Old Dec 27, 2008 | 09:55 AM
4rnr's Avatar
take a wire wheel to the balls to get all the old crap out.
Old Dec 27, 2008 | 05:09 PM
Yoda's Avatar
Originally Posted by 4rnr
take a wire wheel to the balls .
A little extreme?
I've done the JB after cleaning. Worked good.
JB takes some time to cure, usually overnight. A heat lamp to keep it warm does help. It has to be warm to cure.
Old Dec 27, 2008 | 06:14 PM
TacoNut's Avatar
Owwww!!!
Old Dec 28, 2008 | 03:59 PM
toyospearo's Avatar
24hrs later and two heat lamps 3" away and the JB Weld is fully cured. Amazingly it acts just like bondo (which I am far too familiar with.) lol
I took the JB W down very close to the edge and feathered it out. It is NOT a cosmetic fix but rather a functioning fix. I also put a little on the inside outside of the inner axle seal housing.
I cant see any reason why this procedure wont work to help maintain fit and seal.
Sorry about the big pics..
Old Dec 29, 2008 | 09:50 PM
agusgus3's Avatar
sweet, I'm going to do that when i get back. looks good.
Old Dec 30, 2008 | 05:35 AM
toyospearo's Avatar
It definitely filled in the pitting!
Old Dec 30, 2008 | 07:17 AM
tc's Avatar
tc
You need to check out Russell's (vwfastg60) build thread in the 2nd gen forum ... he polished his to a gleaming shine...
Old Dec 30, 2008 | 02:22 PM
LTrunner's Avatar
JB weld seems like it might work...but i wounder how long it would last
Old Dec 30, 2008 | 02:25 PM
mouse4x4's Avatar
It will last longer then the bare metal as long as the surface was clean for it to stick to that is some tuff stuff
Old Jan 2, 2009 | 05:09 AM
vwfastg60's Avatar
My balls
no pits
Old Jan 2, 2009 | 05:11 AM
ozziesironmanoffroad's Avatar
ouch, dont even want to think about that...
Old Jan 7, 2009 | 08:10 PM
924runner's Avatar
i used a few coats of paint
aowRS
Sep 13, 2017 08:22 AM
runnermedic
13
Sep 21, 2015 05:20 PM
MudDr
Sep 12, 2015 01:47 AM
justdifferentials
Sep 5, 2015 06:52 PM
