About driveshafts after SAS
Old Aug 10, 2007 | 10:42 AM
Blizzard's Avatar
Hello,
I'm trying to collect parts and info about my future SAS. As SAS are not very (Nor little!) common in Spain, today's question is about driveshafts.
I'll be running Marlin Crawler 5'' leaves in the rear and 4'' ones in the front.
Today I've been in a salvage yard where they've one Hilux with live front axle, like the one I took my axle off. The stock front driveshaft is a double cardan joint one and the right length for a solid axle. Do you think I must buy it? I suppose that maybe it would need to have a long slip yoke welded but it's ok to test and probably modify it?
I've took a pair of pics of it with the cell phone:
What's the difference between this driveshaft and the IFS one? The lenght? Or the flange pattern at the diff side?
Another one is the rear... I won't be putting dual cases. Do you think I'll need to modify the rear driveshaft, put a double cardan joint or a long slip yoke?
Thanks a lot!
David
Old Aug 10, 2007 | 11:48 AM
waskillywabbit's Avatar
IFS front d shaft u joints cannot handle SAS angles
You need at least an 8" slip spline up front with a CV
You will want to lengthen the front and rear d shafts
Old Aug 10, 2007 | 12:04 PM
Blizzard's Avatar
So do you think the correct would be buy the shaft pictured and weld a log slip yoke?
And the rear? Only lenghten it or I also need a doble cardan joint?
David
Old Aug 10, 2007 | 12:56 PM
4RunnerKid's Avatar
i couldn't run a CV joint on my front shaft because of the angle. i know you can clearance them for more angle, but without duals i don't think it would be enough.
Old Aug 10, 2007 | 01:18 PM
Blizzard's Avatar
This is something a bit extrange isn't it? I think the good think about CV joints is that they are good to save the steep angles aren't they?
David
Old Aug 10, 2007 | 01:21 PM
Tofer's Avatar
Sponsor
i used my old IFS shaft ends... but welded them to square shafts. they were a lil bit of PITA to convince to go into place at that angle, but they did it and have been that way for a year.
Old Aug 10, 2007 | 03:16 PM
Dingman's Avatar
I just put a 8" slip on my front DS, and it's been fine. The rear, I don't think has had any changes made to it. But, I'm not lifted way high either.
Old Aug 11, 2007 | 12:18 AM
Blizzard's Avatar
Thankd Dingman,
And are the stock 85 DS as the one I pictured in that Hilux? Those Hilux weren't sold in the US, they hare a hybrid, newer body with older frame hehe
David
Old Sep 8, 2007 | 03:09 PM
4Crawler's Avatar
An IFS CV shaft can be modifed for more angle:
- http://www.4x4wire.com/toyota/tech/cvmod/
U-joints can handle more angle than even a modified CV joint and they are shorter overall, so the shaft angle is somewhat less with 2 u-joints and with one and a CV.
Old Sep 8, 2007 | 08:12 PM
4rnr's Avatar
Im running a pair of high angle drivelines shafts. a clearanced CV out back and a U-joint up front, a CV can not handle the front end angles.
Old Sep 9, 2007 | 12:11 AM
Blizzard's Avatar
Wow, what a lot of possibilities...
Then... I've my stock driveshafts of my 94 4Runner and a long travel slip yoke I've bough with the SAS kit.
What have I to do?
- Shortening the rear driveline and putting the long slip yoke and using it as front DS?
- Clearance front CV shaft and lenghten it and use it in the rear?
I've also the possibility of buying a front CV driveshaft from a solid axled truck...
Sorry for asking so many times but I'm new to DS tech...
David
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
