2wd-> 4wd
Old Jul 24, 2007 | 06:48 PM
redvette's Avatar
2wd-> 4wd
Would I be able to make my '85 2wd into an SA 4WD? As in, can I use the 2wd frame?
Old Jul 24, 2007 | 06:50 PM
4Runner92sr5's Avatar
i would imagine not since the 4x4 frame has to be much tougher and better gusseted but i have no idea its the first thing that comes to mind maybe the frame is the same hopefully someone that owns a mid 80's truck can give you a better answer
Old Jul 25, 2007 | 04:36 AM
chimmike's Avatar
uh, IIRC, the frames are exactly the same, just one has 4wd and one doesn't.....
Old Jul 25, 2007 | 09:42 AM
anthony1's Avatar
I'm not sure if they are the same. I do know that Downey Offroad sells a kit to reinforce the front end of the frame when they lift it for high speed launch.
Old Jul 25, 2007 | 09:55 AM
chimmike's Avatar
that's for long travel, when doing jumps, iirc.
Old Jul 25, 2007 | 10:30 AM
gilby4runner's Avatar
https://www.yotatech.com/forums/f88/...2wd-4wd-96255/
Old Jul 25, 2007 | 11:08 AM
Flygtenstein's Avatar
You can put a solid axle on most anything, that question is how easy.
Please help with the pics of the reinforced and gusseted parts of the 4wd frame.
On that generation of truck, the solid axle frames have more arch compared to later IFS. Not sure if that holds for IFS 2wd.
Old Jul 28, 2007 | 09:36 AM
rockota's Avatar
Yes, you can use the 2wd frame. In fact, it's actually slightly preferably as it's dimensions are almost identical to a pre IFS 4wd frame. 4RnrRick did a SAS on an 96 2wd xtracab recently and also has a full side-by-side 2wd/4wd frame comparison. I'd post a link, but the search on PBB is having problems right now.
If I were building one, this is teh way I would go.
lots of info here: http://www.pirate4x4.com/forum/showthread.php?t=447914
Old Jul 28, 2007 | 09:52 AM
CASTAIC 4RUNNER's Avatar
same frame, ones 2wd and ones 4wd thats it
kawazx636
Oct 6, 2021 03:03 PM
Daenerysdad
Oct 1, 2015 07:33 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
May-39
Sep 6, 2015 01:05 PM
