1990 2door 4runner SAS slow build
Old Nov 5, 2013 | 03:07 PM
  #101
85sr5excab's Avatar
Patience grasshopper.......if u wait, it will come. Lol. Looking forward to seeing the finished product.
Old Nov 5, 2013 | 09:10 PM
  #102
Xeo's Avatar
Xeo
Well while i was sitting under the rig picking away at the rust and what not i started thinking about how to mount my shocks. Seeing as how this is my daily driver id like to keep the ride quality decent lol so i figured id mount them like this I I instead of /\ also i have limited space under there and from what ive read mounting the shocks /\ that way makes the ride garbage anyways heres what im talking about, mind you its just hanging there lol
I also painted the rusty parts
Old Nov 6, 2013 | 04:21 AM
  #103
bump530's Avatar
That's how I intend to mount my rear shocks when I do mine.
Old Nov 6, 2013 | 05:35 AM
  #104
Xeo's Avatar
Xeo
Well at least I'm not the only one lol my old man thinks it looks funny that way well if you look at it through the side of the fender well
Sent from my moon base.
Old Nov 6, 2013 | 08:09 AM
  #105
Teuf's Avatar
Isn't that the way its mounted stock?
Old Nov 6, 2013 | 09:16 AM
  #106
Xeo's Avatar
Xeo
Not on the second gen 4runners maybe on pickups?
Old Nov 7, 2013 | 09:17 PM
  #107
Xeo's Avatar
Xeo
Update
So i finally got my AAL's today and threw em on my hybrid pack and guess what!?
They helped bring up the rear enough so it doesnt look like its taking off lol and thejack stand isnt doing anything in case you were wondering haha
and lastly my rear upper shock mounts welded on ya ya there not pretty lol
Thats it for now
Old Nov 8, 2013 | 06:53 AM
  #108
julsruls's Avatar
looking forward to how you think it goes with the aal's! Looking good
Old Nov 8, 2013 | 07:35 AM
  #109
Xeo's Avatar
Xeo
Well it doesn't look raked anymore which is what I was trying to get rid of lol now it looks even kinda haha
Old Nov 8, 2013 | 08:59 AM
  #110
bump530's Avatar
Looks good. Curious to see how that affects the flex.
Old Nov 8, 2013 | 10:24 AM
  #111
julsruls's Avatar
yes rake looks stupid. I agree but ya hopefully its doesn't ruin your ride quality or flex potential.
Old Nov 8, 2013 | 12:35 PM
  #112
Xeo's Avatar
Xeo
I hope not as well I'll let you guys know once I actually drive it
Old Nov 11, 2013 | 08:59 PM
  #113
Xeo's Avatar
Xeo
Not much progress on the rig still painting the frame and axle also have the diff out since my little bro just ordered me a Spartan looks like i owe him a xbox one lol
But i did make some progress on the front driveshaft. So what my old man and I decided to do was chop up my old automatic driveshaft, shorten it, use the pinion flange from the double cardan, cut the slip yoke portion at the base and weld that to the double cardan flange and well pictures speak louder than words....
Cost me nothing, thats at ride height, held tpgether by tack welds, turns freely/no binding and yes its ugly lol
Old Nov 12, 2013 | 08:03 AM
  #114
osv's Avatar
osv
that driveshaft angle looks really steep, have you measured it with one of those cheap bubble protractors?
if the flanges aren't parallel, it'll vibrate.
Old Nov 12, 2013 | 08:27 AM
  #115
julsruls's Avatar
Ya I would want to rotate pinion angle up on axle
Old Nov 12, 2013 | 08:55 AM
  #116
Xeo's Avatar
Xeo
I know it's best to have the pinions facing up towards the transfer case but for me to cut off the perches and shock mounts on the front axle and rotate it up like the rear axle is now is troublesome plus the truck is part time 4wd so i can leave it in 2wd with the hubs unlocked and not worry about the front spinning so I'll live with it until i get fed up and I've seen worse lol
Old Nov 12, 2013 | 09:12 AM
  #117
Teuf's Avatar
If you rotate your front axle up to point to the transfer case it screws up the steering and toe in. If its a trail rig only this may not be an issue. If anything shorten the shackle by 1 inch or so.
Old Nov 12, 2013 | 09:23 AM
  #118
Xeo's Avatar
Xeo
I knew there was something I missed thanks Teuf
Old Nov 12, 2013 | 09:59 AM
  #119
osv's Avatar
osv
ideally you cut and rotate the housing, which means that the front end alignment is not changed from stock... the truck goes down the road just like it did before.
as it sits now, you should use the protractor to confirm that 1)the flanges are parallel, and 2)the driveshaft angle isn't too steep for the ujoints.
if they are out of spec, the fix for both is a double cardan(cv) driveshaft.
here is a link for more info:
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Old Nov 12, 2013 | 10:19 AM
  #120
bump530's Avatar
To rotate the pinion properly, you will have to cut and turn the knuckleballs also.
