Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
Homemade Bridge-building
Old Jun 28, 2004 | 12:39 PM
Skydigger's Avatar
A few friends and I have found an old access road here on Vancouver Island that may go through to some interesting spot according to our maps.
The problem is that a few kilometres up the road, there is a large ditch measuring about 12' deep by 10' across.
We'd like to build a bridge to drive across and could use some input from anyone who has done such. The trees in this area are mostly Alders and this is what we'd be using for construction.
Any tips and/or suggestion?
Thanks much,
Warren
Old Jun 28, 2004 | 02:06 PM
Rammbo20's Avatar
I would get some railroad ties if at all possible you'll find them cheap and effective.
Old Jun 28, 2004 | 02:59 PM
shazaam's Avatar
get a couple of generators, some hose, and a couple of pumps and drain it ...
Old Jun 28, 2004 | 03:40 PM
DevinSixtySeven's Avatar
do you have a couple sets of bridging ladders that you could link together and support from below, rather than constructing a permanent bridge?
-sean
Old Jun 28, 2004 | 05:00 PM
Skydigger's Avatar
The ditch is not driveable and there is no water in it. I don't want to build anything permanent (just enough to last a few seasons) and I'd prefer to use materials that would be easily found in the area and not haul anything up there other than saws, rope and maybe some large spikes.
Thanks for the feedback...
Warren
Old Jun 28, 2004 | 06:33 PM
alanh's Avatar
Many bridges have been built just by spanning the gap with large timbers or whole logs. If you don't have logs big enough, you'd have to anchor smaller ones together some way (like wrap steel cable around to strap them together) to create a surface for each set of wheels as a minimum. Another way is big logs spanning the gap with smaller ones from one log to the other to create a deck. Lacking large logs, look at how railroad trestles are built. Of course, you also have to worry about what your logs/timers are resting on to make sure it doesn't give way.
However, if you don't really know what you're doing, and don't want to study up a bit on building such things, you should probably forget the whole idea. Do you really want to experiment and have your rig, with you driving it, fall into that ditch because you guessed at how strong it needs to be and didn't get it quite right?
If you want to continue, the construction and building industry has span tables for wood timbers that would tell how large a timber needs to be to span distance x and support mass y for different species and grades of timber.
Old Jun 28, 2004 | 07:02 PM
Newdad's Avatar
I say build a couple ramps and Evil Kenevil it!
Old Jun 28, 2004 | 07:17 PM
96LtdYota's Avatar
i second that
Old Jun 28, 2004 | 09:01 PM
neil_P_smith's Avatar
Talking use the timbers that are around
my boss had to build a bridge for his drive way. it is maby 20-25 feet across and the hole suport system is made out of 12x8" beams and there is two suport posts. side view ----|----|----
the suport posts are cemented in to a little pad because the bridge is over a stream and it is soft. the deck of the bridge is made of 8x6" boards. he has said several times that the 8x6 s are just for looks and a little extra width for driving on. he has had many heavy trucks (small flatbed semis with dual axeles and a load of lumber) go across is with no thought of any problems. the only thing he dosent let go across is cement and dump trucks. he is a house bulder/ general contractor so he knows his wood and load ratings. if it were me i would drop a few trees that are a good 15" in diameter. then lay two at each side of the tracks with 5-8' of overlap on to good salid ground on each end. i would also make some sort of deck on each side for the tires to ride on. brace it in the center and it should hold a lot more than you will put on it. it is only 10' asross
Old Jun 29, 2004 | 05:10 AM
Skydigger's Avatar
Cheers, thanks!
Old Jun 29, 2004 | 06:39 AM
RobT2k's Avatar
Wow, who's gonna be the first to test drive the bridge? Major white knuckler!
Old Jun 29, 2004 | 09:14 AM
Robinhood150's Avatar
Whatever you do, make sure you take a video camera for the 1st test drive!
Old Jun 29, 2004 | 09:43 AM
Skydigger's Avatar
That'd most likely be me.
I'll be sure to video it!
Warren
Old Jun 29, 2004 | 11:40 AM
Mad Chemist's Avatar
The question to be asked is- who owns the land, and what laws might you be breaking by building the bridge?
Old Jun 29, 2004 | 12:50 PM
Skydigger's Avatar
Well, it's Crown land (provincial Gov't) and it's a de-activated logging road so it shouldn't be a problem.
Old Jul 5, 2004 | 05:44 PM
Skydigger's Avatar
well, it seemed to work ok...
Old Jul 11, 2004 | 08:00 PM
Talking sweet
that looks good, it is a shorter distance than i thought, i hope it holds for some time did it flex at all how did it look.
Old Jul 11, 2004 | 08:47 PM
Skydigger's Avatar
Yes. The logs are close to 17' each and we used two per side.
It didn't flex at all...probably because we braced the middles from underneath with a straight-up-and-down log.
I hope it lasts too; maybe get a year out of it before I stop trusting so much.
Warren
Old Jul 11, 2004 | 08:53 PM
Scofco's Avatar
Solid looking!
It would keep people like me off the trail also, I wouldn't trust that thing with my rig unless I built it!
Was it worth the build? I hope the road after that is impressive enough.
chukarhunt
Dec 8, 2019 11:39 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
altydog
Aug 30, 2015 06:44 AM
94ofCanada
Aug 14, 2015 06:37 AM
olharleyman
Nov 29, 2007 04:34 PM
