Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
ARB Air Locker Install?
Old May 29, 2002 | 06:09 PM
Gene's Avatar
Howdy!
I'm prepping for my ARB install coming up this Saturday and was wondering if anyone knows of a good write-up of the installation on a 3rd Gen 4Runner (or equv).
I would also be interested to see where 3rd Genners are mounting the compressor. There's not a heck of a lot of room under the hood! I am currently considering the rear compartment but I am loath to drill holes there.
Anyone?
Old May 29, 2002 | 06:30 PM
Shane's Avatar
Here ya go, not 3rd-gen but it's pretty much the same differential in the rear.
Old May 29, 2002 | 06:32 PM
Corey's Avatar
Co-Founder/Administrator
Gene, sorry I can't help you here, but are you going to be down at Central 4WD in Kent for this?
If so, if you are going to be there for the install, I may swing by to meet ya.
Corey
Old May 29, 2002 | 06:36 PM
sschaefer3's Avatar
Your welcome again.
http://home.earthlink.net/~larsdennert/4runner/arb/
:rolleyes:
Old May 29, 2002 | 06:39 PM
Gene's Avatar
Well... I have worked out a deal, through a freind, with some of the *extremely* qualified techs to do it in their off hours. Saved me about $500.00 in labor!
C4WD wanted $700.00 just for labor! Ouch! My wife was not buying that. Hell, the parts alone were around $900.00 when including taxes.
Once I get this done, I will be itching to try it out. We should put together a NW Run!
Old May 29, 2002 | 06:55 PM
Corey's Avatar
O o p s, I can tell I'm tired tonight
You would not need a write-up if you were having Central do it.
Yeah, I was quoted about $1800 from them for a rear Air Locker, and new Timkim bearings, and the labor.
Regarless, they always put in new bearings to be safe.
And that was for my stock gears still.
I was almost thinking of heading up to Greenwater Saturday morning for just a few hours to explore a bit, but I'm not sure if I'm going to get up there or not this weekend.
Probably wait a few more.
Corey
Old May 29, 2002 | 06:59 PM
Shane's Avatar
Originally posted by Gene
C4WD wanted $700.00 just for labor!.... Hell, the parts alone were around $900.00 when including taxes.
See. This is why the Toy electric locker is a much better deal. $750 for parts, a little welding and grinding and a few new studs, $25 at RatShack, and you've got yourself a very reliable locker.
Old May 29, 2002 | 07:03 PM
Gene's Avatar
The people who are doing the install are most likely the best people in the area to do the install - let's just say that they are not "third-party".
I am looking for a write-up to keep up with them. I will be doing the compressor install myself so a little help there would be nice. I'm still searching!
Old May 29, 2002 | 07:05 PM
Corey's Avatar
That is what I want to do Shane in the future.
Only thing is my rig could not be down for more than the day it's being worked on.
I will have to look into this more in the future. I even think Inchworm is selling 3rds all setup already where you just swap out your 3rd, and re-use your own axles right?
I think I read you have to get a new ECU box too? If so, to bad you just can't supply the spark to the wiring to fire it up.
The elusive Eaton E Locker for the vehicles it goes into already only has two wires. Positive and negative, and your switch.
Corey
Old May 29, 2002 | 07:09 PM
Shane's Avatar
Corey, remember that the 3rd member and the axle housing are two different things. On that note, yes, Inchworm is modifying axle housings for an extra $125. Also, you can either build the control box for the locker, or buy the stock "ECU" box from a junkyard. There's some info here on wiring the locker.
Old May 29, 2002 | 07:18 PM
Corey's Avatar
Thanks, I will have to bookmark those and read up on it.
All I need is a nice Toy E locker, and a new rear bumper from Badlands, and I'm set.
Screw lower gears, I don't need to go faster than I do now
Corey
Old May 29, 2002 | 09:41 PM
Robinhood150's Avatar
Doesn't downey make a cable retrofit for the e-locker? I think they do.
Aaargh....get a taco or keep the 4runner.... still debating...
Old May 29, 2002 | 09:54 PM
Shane's Avatar
Yes, they have it listed on this page of their site. No idea on price though...
Old May 30, 2002 | 06:02 AM
I think i paid around $500 to install my rear ARB locker and that included the install kit and bearing,when i did the one in the front I just handed them the diff. ,locker,gears and install kit the charge for labor was $200.
Old Jun 2, 2002 | 06:37 PM
Gene's Avatar
Well, the install went okay. Once we got things broken down, we noticed that the pinions bearings were bad. Luckily, we had resources within out grasp.
It took about 4 hours to do. I can't wait to install the compressor and hit the hills to try it out. Finding a good location for this compressor is hard! All the Taco guys have this perfect spot, just begging for a compressor. In my Y2K Runner, it just were the ABS sits... Damn!
I'd hate to have to mount it in the back of the cabin, but I may not have a choice. Either way, I guess it's a good problem to have!
Old Jun 2, 2002 | 07:06 PM
Corey's Avatar
Gene, just a thought here.
You know those JL Audio Stealth boxes that sit on the side of the hump for a sub woofer?
I wonder if you could house the ARB compressor in it?
With it enclosed and with sound deadening, you might not hear it too much.
If heat was a concern, mount a fan in the box like Jim (mytruck) did with his Phoenix Gold amp install in the back of his Extracab.
Corey
Old Jun 3, 2002 | 06:10 AM
Gene's Avatar
Hmmm... Thats not a bad idea. I'll give it some thought. Thanks!
Old Jun 3, 2002 | 05:47 PM
Corey's Avatar
Gene, check out the box in the back of John & Kim's '90.
Something like that might really do it.
Corey
Old Jun 3, 2002 | 06:51 PM
jx94148's Avatar
Corey
I'm pretty sure you know that lower gears = lower speed per motor RPM.
Slower, faster, whatever... Toy E-Lockers rule!!
Old Jun 3, 2002 | 07:07 PM
Corey's Avatar
Yeah, what I meant was faster take off speed due to the lower gear ratio.
If I need to go faster, I'll real out my winch line with my handy dandy Ramsey Wireless Remote, and lasso me a sports car to get me up to speed
Corey
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
coryc85
Sep 9, 2015 06:24 AM
coffey50
Jul 28, 2015 10:55 AM
A2theK
Jul 12, 2015 10:46 AM
