This worth buying?
This worth buying?
Ok guys so after much searching for a 4 runner I found this
I am looking to sell my 1994 Toyota 4runner 4x4 automatic full powerd windows and locks as well as rear window and sunroof the car is a solid 9 out of 10.. The motor was just rebuilt (10k miles ago i have all recipts) new head gasket,heads,belts, valve job new battery, fog lights swaybar bushings a fail safe thermostat and i am sure i am leaving out a few things runs great shifts smooth. It also has a 4" suspension lift with new pro comp shocks, has new brake pads Micky Thompson beadlocks with red rings looks great, the tires have less the 4k miles on them have been rotated once they are 32x11.5x15 it has a aftermarket air intake ( i have stock intake as well) and a TRD exhaust Warn Locking Hubs, the front has 2" billet spacers to make front wide alighment was just done car is solid drives like new nice and tight interior is near flawless one of the cleanest 4runners you will ever see..oh ya it does have a cd player
I talked to the seller he seems knowledgeable and picked it up from another guy he says its ' tight and solid, wife uses it to commute up the hill and back, I have other toys for offloading"
What do you think? hes asking 5,700 or OBO.
I think the fact it has the hated WARN hubs should drop at least $2500.00 from the first offer!!
The real Question is how bad do you think you have to have this one?
I have seen it all to often we all do it at one time or other with something
Good luck in any case no matter how it turns out
here is one I saw on auto trader. I dont know if you like the 22re 4cyl with a 5 speed
http://www.autotrader.com/fyc/vdp.js...standard=false
1995 was the last year of the 3.0L 3VZE. 3.4L was used for the '96 model year (produced midway through 95.)
Both trucks and 4runners underwent a pretty serious design change that year! Body styles changed quite significantly as well.
skoti89
Jul 8, 2015 12:05 AM
