Buying & Selling Advice - Feeler/Gauging Interest This general forum is for those seeking information about buying, model features/differences, pricing to sell, and related advice
how does this short block motor look?
Old Jan 14, 2012 | 10:59 AM
rockthepouch's Avatar
I am thinking about buying this short block with 165K miles. Owner says it had a valve issue. Does anything on this look bad? Going to put in my 1991 w a blown head gasket, doing a valve job obviously...
I know it's hard to diagnose, but any input would be great!
Thanks in advance!
Old Jan 14, 2012 | 11:04 AM
sixstringslut's Avatar
Looks like expensive project to me. You sure it would not be easier to fix your HG?
Old Jan 14, 2012 | 11:17 AM
my 4runner has 278K miles on it, this engine has just under 165K so I'm thinking, redo the heads on this and drop it in, sell the other bits of the old motor. So I can work on it out of the car...I think I can pickup this short block for $200...how much do you think it would cost to do a valve job/head refurb on this? I am new to the 4runner crowd but have a 96 Landcruiser that is my DD...
Old Jan 14, 2012 | 11:18 AM
I don't wanna do head gaskets on an oldE1`
Old Jan 14, 2012 | 11:20 AM
abecedarian's Avatar
Thanks in advance!
Valve issue? What's that?
Sucking a valve in, or...?
Buying a used engine with a known problem is setting yourself up for costly repairs.
Old Jan 14, 2012 | 11:33 AM
I am not sure..gonna pull the heads and see if the valve hit the piston/cylinder wall
Old Jan 15, 2012 | 12:26 PM
FOLLOW UP!!!
So I bought the motor last night and started tearing it apart today. Got both the heads off and now working on getting the main off. Next question is how do I get that front sprocket dealy off the front of the motor?
Here are pics:
Right side head gasket had a weird goopy crap in one spot....
the backside of the right side head gasket
underneath the gasket, the block looked rusty/burnt?
right front cylinder #1?
right side middle cylinder
right side back cylinder
left bank
Old Jan 15, 2012 | 01:28 PM
cziemer's Avatar
The timing belt sprocket on the crankshaft is *suppose* to just slide off. This is usually not the case, the FSM says to use 2 screw drivers prying on opposite sides. Mine took 2 large prybars and a little heat. If you use heat make sure to be careful (the oil pump is right behind it) and replace the seal that is right there while you're in there. Cylinder walls and lower end look ok, but it's hard to tell from the pictures. I had the same goopy stuff in the dead-ended coolant passages when I did my head gaskets a couple weeks ago.
Old Jan 15, 2012 | 02:20 PM
gubni's Avatar
Feel inside the cylinders for any pitting or roughness on the walls.
cars-guy
Aug 16, 2020 06:59 AM
okamikai
Apr 30, 2018 10:19 PM
dumpster84
Apr 30, 2016 06:03 AM
jon.r
Jul 11, 2015 03:34 PM
Coreyr384
Jul 10, 2015 11:13 AM
