93-98 T100s All T100 trucks
New here with a question
Old May 1, 2014 | 11:49 AM
wiblueboy's Avatar
Hi there. I'm picking up a 95 t100 5speed 4x4 on Saturday. It's going to be my hunting truck for bear hunting with my hounds. It is stock height with 15 inch rims. What are the biggest tires I can run on it? It shouldn't make a difference but it does have a flatbed on it. Thanks guys!
Old May 1, 2014 | 12:18 PM
HighLux's Avatar
No bear hunting allowed on Yotatech.
Sorry man...smokey the bear is a moderator here...
Welcome. Probably excited about that truck I bet.
Surely be better for deer hunting or something besides cuddly little bears. Something worth actually eating?
Just giving you ˟˟˟˟...but I could never shoot a bear..unless it was life or death.
Old May 1, 2014 | 02:33 PM
wiblueboy's Avatar
Sorry not trying to make people mad on my first post.. Just excited and wasn't sure what tire size I could go up to
Old May 1, 2014 | 09:15 PM
CJM's Avatar
CJM
Can easily clear 33x10.5x15 if you take the mud flaps off the front. Will fit 32x11.5 no issue and LT 265/75/16 (if you go up in wheel size).
Old May 1, 2014 | 09:18 PM
HighLux's Avatar
Im just messin with ya man!! lol.
Hunt whatever you want....lol. (I do like bears though!)
Grats on the Toyota. Gonna be fun fixing it up and stuff.
Old May 2, 2014 | 04:22 AM
wiblueboy's Avatar
Here's a few pics of it. Needs some work but I don't think it's too bad for $1000. Gonna make a new flat bed, make a tube bumper like the ol smitty ones and might lift it 3"
Old May 2, 2014 | 04:44 PM
CJM's Avatar
CJM
That flatbed might be an issue on the rear wheels because it looks like if you were to load the bed down enough it would rub or larger tires would rub ont he bed.
Old May 2, 2014 | 04:56 PM
The Tick's Avatar
Originally Posted by CJM
That flatbed might be an issue on the rear wheels because it looks like if you were to load the bed down enough it would rub or larger tires would rub on the bed.
+1 you will need a rear lift or a higher bed to clear bigger tires. I'd stick with the ones that are on there until you can lift it and/or build a higher bed.
Old May 2, 2014 | 06:10 PM
HighLux's Avatar
Wow what a great big shop to work in....jealous!
Old May 2, 2014 | 08:05 PM
wiblueboy's Avatar
Here's a better pic showing the clearance. Currently has 31 10.5 15. I figured it could at least fit 32 11.5 15..
Old May 5, 2014 | 04:00 PM
BamZipPow's Avatar
I'm guessing you have the 3.0L 6-cylinder engine (3vze) based on the exhaust pipe is on the driver's side? I find it weird that the previous owner installed the driver's side gas tank as well as that would be an indicator that you would have the 5vzfe engine.
Old May 5, 2014 | 05:02 PM
FourwheelinVT's Avatar
The clearance with the bed will be more of an issue during flex/compression of the suspension. Measure the distance between the bumpstop and the top of the leaf spring, that will be how much "up travel" the suspension has. Then measure the distance between the top of the tire and the bed, if it is less, then it will rub. You could always just cut the bed over the tires and add higher wheel wells.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
