93-98 T100s All T100 trucks
My 95 5spd is having a hard time shifting into 1st & 2nd
Old May 27, 2013 | 11:21 AM
LVWAX's Avatar
I got a 95 5spd 2wd and I got to basically force it into 1st most of the time. I know this ain't good for the tranny so does anyone know if this is an easy fix? Or is my transmission going to be done for?
Old May 27, 2013 | 04:56 PM
youngtoyotatech's Avatar
Any differnce with the engine running or off
Old May 27, 2013 | 09:27 PM
BamZipPow's Avatar
Do you have the upgraded clutch pedal bracket? If you do, it should be painted black. If it's steel/rust colored, it could be cracked and causing you problems.
How good are yer shifter seat bushings? When was the last time you inspected/replaced them? Marlin Crawler has a nice replacement one that's much better than the OEM one.
I believe you will need the white seat.
http://www.marlincrawler.com/transmi...ver-ball-seats
You might want to pick up the shifter bushing as well...
http://www.marlincrawler.com/transmi...t-lever-socket
Old May 27, 2013 | 09:52 PM
LVWAX's Avatar
No running or not it still giving me a hard time. I don't think the bushings have ever been replaced. I will definitely check out those web sites and get them replaced a.s.a.p. thanks alot for the help I appreciate it.
Old Jun 7, 2013 | 05:07 PM
LVWAX's Avatar
So I replaced both the shifter bushing as well as the seat bushing and when the truck is not running it shifts fine but while running I still have to force it into 1st. I checked the clutch it is the black one. So do you know of anything else it could be?
Old Jun 7, 2013 | 05:22 PM
Bullet22r's Avatar
my only guess is that check the clutch system, see if their is the right enough brake fluid in the clutch cylinder, check the clutch slave and when was the last time you check the gear oil in your tranny, if it isnt any of those than it could be time for a tranny rebuild.
Old Jun 7, 2013 | 05:31 PM
LVWAX's Avatar
I'm not sure of the maintenance its had so I'll try all of those suggestions, I don't want to have to get a rebuild. Thanks for the suggestions.
Old Jun 8, 2013 | 09:25 AM
BamZipPow's Avatar
The next thing to check is the master and slave units. You can rebuild them with a kit from the dealership or just replace them with rebuilt/new units from yer favorite auto parts place. Rock Auto usually has some good deals on some close outs.
If you want to go with OEM parts, give ToyoPartsMan over at ToyotaNation.com (aka Gary at Newnan Toyota) a buzz. Let him know that Bam sent yah.
Old Jul 6, 2013 | 04:33 PM
LVWAX's Avatar
I had checked everything and it ended up being the clutch plate. 2 of the "teeth" on it had broke off and were just tearing up the inside of the bell housing. Luckily I found it and fixed it before any real damage was done. So if you ever come accross that issue now you know what it is.
CJ94yota
Jul 3, 2015 10:14 PM
ZONAYODA
Jun 30, 2015 05:36 PM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
David_Vestfal
Jun 20, 2002 08:30 PM
