Loose Parking Brake?
Does anyone have a guide on how to run new parking brake cable or adjust the current cables?
I just purchased a 94 T100 2WD with the 3.0 in it. Love the truck but the emergency brake when pulled is super light and does nothing to stop the car.
Thanks
Thanks
Very easy, there is an adjustment at both the drums and also under the truck. You will understand if you crawl under there.
Its also possible the shoes are not adjusted enough. You want to adjust them so the drum drags a good bit but enough it can spin with a hard shove.
So I crawled up under the bed today and took a look around. All I found was the cable coming from the parking brake handle with the spring on the end of it. Looks like this part http://www.rockauto.com/catalog/more...556&cc=1278659, and it was loose and zip tied to the driver side frame rail right above the axle. Does anyone have schematic as to what it needs to be connected to or what parts I may need to buy. Any walk through or advise would be much appreciated.
Thanks
Thanks
Thanks for the link, That def helps some. was able to find out the cable and fastener parts, but I'm wondering if everything will work properly on my truck. I'm also missing the hinged arms the cables attach to on the back of my drums. Cant for the life of me find these part number. On the drivers side I can tell where it is supposed to go but on the passenger side I see no evidence of that hinge ever being there. Am I in trouble? I'll try and attach some pictures.
Passenger Side
Driver Side
Driver Side Cable Ziptied to framerail
Passenger Side
Driver Side
Hi guys,
My e brake seems to have disconnected somewhere near the cab (in a spot that is not visible for underneath). I can get under the pickup and pull the cable lose (from the housing tube, pulling from the front towards the rear). Does anyone have any suggestions or possible directions to fix the problem. I'm thinking I may have to replace the whole cable, but not positive.
This is on a 95 pickup by the way.
He definitely needs all of the bell crank parts, some which are attached to the insides of the backing plate. It's a bunch of parts. The best bet would be to get both complete axles off of a "donor" at a salvage yard for each side. If the salvage yard can get the whole backing plate off that would help, but it isn't a pick and pull. The backing plate is pressed on and held tight with a mo-fo retainer.
IHTH - Mark
terminator
Jul 27, 2015 07:13 PM
CanRunner
Jul 20, 2015 01:29 PM
