93-98 T100s All T100 trucks
ball joint spacers
Old Feb 28, 2006 | 04:46 AM
tickt9842's Avatar
ball joint spacers
where can i get ball joint spacers, add a leaf , gears ( 529 ) and lockers for a good price???
Old Feb 28, 2006 | 03:12 PM
Kookadala's Avatar
5.29 gears? What size tires are you planning on running? You would want to be 37 or greater for that gearing. How about some specs on your truck and what you use it for. The more info you provide the easier it is to answer your questions.
Old Feb 28, 2006 | 03:26 PM
Tacoclimber's Avatar
What he said.
Old Feb 28, 2006 | 03:27 PM
Originally Posted by Tacoclimber
What he said.
Oh yeah, and define "good price"....
Old Mar 1, 2006 | 12:51 AM
tickt9842's Avatar
the 33x13.50 i have now rub pretty bad in the mud. i use the truck in the mud mainly. i want to get at least 35s. i have 4.30 gears stock. what gears should i go with and where should i buy them?? i know im going to need more lift other than the 4" trail master lift to fit the 35s.
Old Mar 1, 2006 | 06:12 AM
Kookadala's Avatar
To fit 35s you want a 4" suspension lift and at least a 2" body lift. My 35s still rub occasionally at full stuff when turning so I wish I had gone with a 3" BL. 4.88 gears match almost exactly for 35" tires, otherwise your speedo will be way off. Too much gearing can lead to broken parts.
Try to find a reputable shop that does gear work, unless you have done this before. There are 4x4 shops all over this country, but I have heard good things about Randy's ring and pinion, plus they always advertise in the Cal4wheel website so should be alright. Where do you live?
Old Mar 1, 2006 | 11:11 PM
tickt9842's Avatar
im from north carolina but i live in gulfport ms because im in the military. ill be there for the next few years. we have an offroad performance shop there but the labor is a bit pricey. what gears do you have? do you have lockers front and rear??
Old Mar 2, 2006 | 10:08 AM
Kookadala's Avatar
I have 4.88 with ARBs front and rear. Very pricey!
Old Mar 3, 2006 | 01:14 AM
tickt9842's Avatar
parts is the only thing thats going to get me. i have a friend thats been a mechanic for 25 years and he builds mud trucks in florida. all i have to do is buy him a case of coors light.
Old Mar 3, 2006 | 01:16 AM
tickt9842's Avatar
with the set up you have now you havent had any problem with everyday driving or problems with your trany or transfer case??
Old Mar 8, 2006 | 09:08 PM
Kookadala's Avatar
No problems on the road at all. I did install a tranny cooler and do a flush to replace the fluid with synthetic. Nothing done to tcase.
Drive to baja or arizona with no problems, other then it starts to shake between 60 and 65, so gotta keep it 70 to be smooth!
Old Mar 8, 2006 | 09:23 PM
rocket's Avatar
Originally Posted by tickt9842
where can i get ball joint spacers....
Click the link in my sig
Old Mar 9, 2006 | 11:10 AM
t100's Avatar
i believe there is a place in mcComb that is still there, they put my bullbar and winch on when my dad first got it.. i will look it up and get back to you.. i will aslo ask some of my friends who lift trucks for a living and see what they charge..
Old Mar 19, 2006 | 07:41 PM
bigbadktm's Avatar
check out sdori for ball joint spacers.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
