93-98 T100s All T100 trucks
96 T100 no start in 1 out of 20 attempts
Old Apr 15, 2012 | 01:14 PM
Sabre2012's Avatar
Exclamation 96 T100 no start in 1 out of 20 attempts
96 T100, manual trans: NO START in 1 out of 20 attempts: new battery: full power to gauges- only 1 click per turn of key- engine turns almost, but cuts out abruptly.
Easier to remove and check the clutch safety switch ? Or starter ? Solenoid ?
Mike..
Old Apr 15, 2012 | 04:11 PM
250000_yota's Avatar
Sounds like starter contacts are starting to go. Dealing with the same issue right now. As they get worse, the clicking will get more frequent (1 in 10, then 1 in 5) and eventually get to the point where it won't start. Contacts are cheaper than a starter, and not that difficult to replace. Only problem is you have to pull the starter first in order to identify which contacts you have, whether you have a cold weather package starter or not (apparently they can't tell you which one is which when you call the dealer, or at least mine can't...)
Old Apr 15, 2012 | 05:06 PM
astephenz's Avatar
fuel perhaps?
Old Apr 15, 2012 | 07:41 PM
VWToy's Avatar
Sounds to me like the solenoid is going out. Could be the clutch switch too but I would lean towards the stater.
Old Apr 16, 2012 | 01:07 PM
Sabre2012's Avatar
Thanks 250000
Giving it a try soon...
Mike
Old Apr 16, 2012 | 07:10 PM
The contacts are in the solenoid portion of the starter itself. Their the replaceable portion.
Old Apr 16, 2012 | 07:40 PM
TylerH's Avatar
x2 on solenoid.
Old Apr 17, 2012 | 01:08 AM
Sabre2012's Avatar
Thanks everyone ! ...is it possible to test the starter without yanking it ? (The guys at the Autozone say they can test it)... I'm trying to conserve energy...but i am curious to see if I can manage to replace the contacts and reassemble the solenoid/starter...
Old Apr 17, 2012 | 02:43 AM
BamZipPow's Avatar
While it might be able to do some basic tests with the starter still installed in the engine...yer still gonna need to pull it to fix it. It's just better to pull it out and fix it.
Here's what it would involve in replacing the contacts...
http://www.4x4wire.com/toyota/maintenance/starter/
Old Apr 17, 2012 | 03:32 PM
TylerH's Avatar
I would just replace it even if it tests good. Unless you test it 20 times.
Old Apr 18, 2012 | 02:12 AM
Sabre2012's Avatar
Thanks BamZipPow & TylerH...In my heart of hearts I knew that is what to do, and everybody would tell me so. If I have to endure one more no start moment, out comes Mr. Starter...
Thanks much.
Doug4320
Mar 24, 2018 10:11 PM
taller1
Jul 16, 2015 03:00 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
