General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Toyota 3vze 3.0l v6 engine hi-pro 190hp/210ftlbs
Old Nov 30, 2011 | 12:56 PM
dubbsbetty's Avatar
Originally Posted by 1991yota
I have the hi pro from motorcrate, runs nice and has good power
Since your the only one who's experienced the hi-pro..... is it worth the money, any engine should run more efficiently/responsive with fresh components, compared to stock is the hi-pro a relative difference, have you had a healthy factory 3VZ you can justifiably compare to? I realize it won't be a a powerhouse, but for that price and the reliability(contrary to some), that's great considering my top-end rebuild with heads machined ran me approx. $1,500 self labor except heads!
Old Apr 3, 2012 | 11:27 AM
4Runner3Wheeler's Avatar
CHS Machine Company OR MotorCrate Soundoff
This thread is relatively fresh...any one on here have any experience that could be shared regarding the 190hp 3.0 3vze from either CHS or MotorCrate???
I agree with some 3.0 owners that a stock for near-stock swap would be nice for the budget and performance if 190hp is attainable from this rebuild.
My budget is roughly $3000 total, which makes the 3.4L swap not doable but this 3.0L plausible if it will truly be worth it. It's easy to just say "3.4L swap", but I'm looking for someone who is using this 190hp 3.0L.
Thank you for any input!
Old Apr 3, 2012 | 11:30 AM
DeathCougar's Avatar
How is a 3.4L swap not doable with $3000?! I am net $1000 into my 3.4 swap on my 87 4Runner! And that includes a BUNCH of brand new OEM parts.
Old Apr 3, 2012 | 11:39 AM
MaK92-4RnR's Avatar
werd.
I think you can buy a engine, harness, and computer w/ low miles for around 1,200 here. Its easily doable if you're looking to do an instant swap. ( no cleaning, or tune up on the engine. just simple drop in and go )
Old Apr 3, 2012 | 11:44 AM
  #25
DeathCougar, you are undoubtedly a badass judging by your name and attitude. I would like input regarding any users of the 3.0L as indicated by the post.
My '93 is a manual making finding a complete engine/accessory setup difficult as they are more rare than an auto setups. Ones I have found have over around 170-230k miles on them for $1500-2000 alone. This doesn't include any rebuild parts or labor, e.g. timing belt, water pump, O2 sensors, harness adaptor, etc... I could buy a remanufactured 3.4L engine, then piecemeal the accessories, but that is less than ideal for harness/ECU related issues. Although, I should be good so long as the ECU is from a manual, but then will I have all the mounting brackets and other niceieties to worry about.
I'm open for any specific input you can provide me to help me have a 3.4L installed with my AC working for under or around $3000. Please PM me. Thanks!
If any one has a 3.4L swappable setup for a manual, preferrable from a '96-98 with low miles, PM me. I'm also interested in T100 and Tacoma 3.4L engines. Thank you!
Old Apr 5, 2012 | 05:19 PM
  #26
mickeycrack18's Avatar
know this is an old thread but was thinking about going the same way and doing some research and saw this on the BBB website it shows they got a D out of A-F with most of there complaints about problems with product/ service and warranty issues http://www.bbb.org/oregon/business-r...nd-or-35001062
Old Jul 1, 2013 | 07:40 PM
  #27
Toreador's Avatar
Hello all,
My 3VZE at 218,000 has blown. Coolant was pouring out all over the drivers side of the engine and all over the street.
I'm not so sure what that problem could be but I'm guessing it's the head gasket.
So I have now decided to replace my broken engine for the Hi-Pro engine.
I will also be buying thorley headers, borla muffler, and some hi-flow cat.
I have a few questions in no particular order.
-How many quarts of oil would this engine take?
-What kind of oil should I put in? and how often should I change it?
-Which parts will I keep from my current engine?
-Which parts will I replace?
I have used search terms such as: 3.0 rebuild parts list, header install, etc.
I have my vafm leaned 2 clicks, should I leave it as that? or return it to stock?
Sorry for the bombardment
Old Jul 29, 2013 | 07:05 PM
  #28
RSR's Avatar
RSR
Drivers side. Coolant lines at top of engine going into throttle body, and coolant lines at bottom of engine going into oil cooler. Check those first.
Also, do yourself a favor and do a 3.4 swap!
Old Oct 10, 2013 | 08:07 PM
  #29
clok's Avatar
Just emailed you...
Old Dec 7, 2013 | 10:56 AM
  #30
nebr yota's Avatar
any companies make a conversion kit?
Old Dec 7, 2013 | 11:50 AM
  #31
donomite49's Avatar
Look up toy only swaps and offroad solutions.
Also look up the 3.4 swap section on yotatech.
Old Dec 9, 2013 | 08:36 AM
  #32
randu2020's Avatar
I bought one in April
From chc machine or raptor engines, they have so many names for whatever reason. To me I woulda have rather rebuilt my old one even though u do have a slight power difference. Def not worth 2 grand, cheap internals, not an oem oil pump like they promised, it was cheap gasket sets and cheap oil pump, cheap pistons,, I was pissed
Old Dec 9, 2013 | 02:52 PM
  #33
RSR's Avatar
RSR
Thank you for sharing. Said it several times -- the only way they can sell engines w/ those power specs for that price is cheap, likely Chinese made internals and probably heads too... Yes, they have a warranty, but that warranty won't save you from the safety/inconvenience of engine problems. Nor does the warranty cover the removal and install of the new engine. Not even sure if it includes the freight shipping of engines to/from. Nor do we know how well these folks stand behind their engines in the warranty dept and how long their inspection period is/your downtime before they'll have a replacement engine to you...
For about the same cost, you can get the same or greater power from a bone stock 5vzfe, and add $1k and you get a fully rebuilt 5vzfe... And arguably have big gains in reliability too -- most 5vzfe swaps report small gains in fuel economy too...
stock 5vzfe being 190 HP, 220 ftlbs torque
vs stock 3vze being 150 HP and 180 ft lbs torque
vz Raptor claiming 190 HP and 210 ftlbs torque
FWIW, while DOA has had a lot of complaints about quality and not delivering what they're selling, their prices are spot on for what one should expect to pay for power-built 3vze w/ OEM+ quality components (probably knock $1.5 to 2k off all packages for basic assembly cost that a home mechanic DIY job that farms out the precision machining should expect to pay): http://doaracingengines.com/6-cylind...ne/v6-engines/
$4750 for rebuilt 175 HP longblock.
$8250 for rebuilt 185 HP longblock
$8650 for rebuilt 205 HP longblock
$9100 for rebuilt 225 HP longblock.
Old Jun 2, 2015 | 12:58 PM
  #34
S3lahsBlue4runner's Avatar
Good engine
Recently finished install on my 1991 toyota 4runner my engine came with an unlimited warnty from the same place it really sucked at first because we hadn't ever worked on any thing close to this we are beginning to get it tunned in beter and it is really beginning to open up to some power still lacking throtle response and a little power in the lowwer rpms but I think it's an ok deal
Old Jun 27, 2016 | 09:51 AM
  #35
supraman1's Avatar
RE: the 190 Hi-Pro 3vze engine:
I'm glad I found this post. I have a 1989 4Runner that I just pulled the 3vze from and was considering the Portland, Oregon PMC 190 Hi-Pro engine. I also have a 5vzfe out of a '00 4Runner, complete drive train, frame and all, the whole damn thing minus body. The Hi-Pro just sounded easier to do since I'm not sure I wanted to go through the headache of swapping in the 5vzfe. But, maybe I better think this over some. Thanks for the post. Good comments.
The Greasy Pig.
Old Apr 20, 2020 | 09:55 PM
  #36
Jordan Schutte's Avatar
3vze engine
Originally Posted by Rexd699
Hi All,
Has anyone used one of these remanfuctured engine built in Portland, OR. Selling for $1995 with CORE Exchange...I found this on eBay...???
I am currently pulling my V-6, 3.0L, 3VZE out of my 1991 4Runner. It is still running but getting tired with 280,000 miles. I live and run out of Reno, NV. Moved here from Boise, ID. both areas have great off road to enjoy.
I have three TOYs: 1991 4Runner, 1995 4Runner, 1980 2x4 Pick-Up
All running great and love to go out and play.
Any good advise as to creating extra HP while I have it out.
I have read about everything I can find but wish to gain all the knowledge/advise I can get...
MANY THANKS...Rex M
xxxxxxxxxxxxxxEngine listed on eBayxxxxxxxxxxxxxxxxx
Motorcrate Engine Sales Portlan, OR.
TOYOTA 3VZE 3.0L V6 REMANUFACTURED HI-PRO / HEAVY DUTY ENGINE
190HP @ 4800 RPM / 210FTLBS @ 4800 RPM
~~~>>>$1,995<<<~~~
THIS ENGINE HAS THE FOLLOWING:
NEW HYPEREUTECTIC PISTONS.
NEW ALUMINUM PERFORMANCE ROD & MAIN BEARINGS.
NEW THRUST BEARINGS.
NEW OIL PUMP.
NEW FULL GASKET SET.
NEW MOLY PISTON RINGS
NEW BRASS FREEZE PLUGS
NEW TIMING BELT
NEW OVERSIZED VALVES, GUIDES & STEM SEALS.
HIGH PERFORMANCE CAMSHAFTS 222 DURATION-.400 LIFT.
MACHINE WORK
Bore and hone block with torque Plate with moly finish.
Deck cylinder block parallel to main line with CBN.
Re-size connecting rods.
Hang and align new pistons onto connecting rods.
Line hone main line.
Grind & polish crankshaft.
Grind & polish camshafts.
Remanufacture Cylinder Heads.
Adjust valves.
Assemble.
Fully balanced assembly!!!
ALL OF OUR ENGINES COME WITH A 7 YEAR / 70,000 MILE WARRANTY!!
ENGINES ARE SOLD EXCHANGE
CORES MUST BE REBUILDABLE
Hey, is there a link you can send me so that I can find this engine on Ebay because I've been searching for it and no luck.
Thanks Jordan
Old Sep 29, 2021 | 07:26 AM
  #37
BYC&F's Avatar
Hi All,
MANY THANKS...Rex M
~~~>>>$1,995<<<~~~
NEW OIL PUMP.
NEW TIMING BELT
MACHINE WORK
Adjust valves.
Assemble.
What do these cost????
Old Dec 28, 2022 | 10:10 AM
  #38
tonyisme's Avatar
Rebuilt 3.0L 3VZE 1990 4Runner 5 speed tranny
I had my 2nd owner 3VZE rebuilt by a certified engine builder. After 5000 mi, so far so good. New Toy cams, pistons, rings. No more CAT. Running good so far.
My motor has 310230 mi I have the 150R manual transmission.
Stick with OEM or used OEM parts whenever possible. Do not go aftermarket fluids or parts unless absolutely necessary. Or you WILL be spending twice the money to replace junk afternarket
bearings, or plug wires or whatever. Most important is proper mix Toyota OEM coolant, and lubricants that don't dry up and evaporate,
arch1995
Feb 21, 2015 12:18 PM
Erik Hinch
Aug 15, 2013 06:15 PM
cheappc
May 1, 2013 05:11 PM
3. Slow
Jan 2, 2010 01:17 PM
Mr.White
Mar 17, 2009 12:59 PM
