General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Tail Light Problem - what to check
Old Jun 25, 2011 | 12:25 PM
jay4runner's Avatar
The drivers side tail light isn't working on 1990 4Runner. Took it out to replace - bulb looks fine. Tried replacing with known working bulbs - no luck. The wiring etc all looks really good. And, the bulbs are making good connection. Everything looks clean etc. Tail light fuse is ok as well. Any ideas what I might check?
Old Jun 25, 2011 | 11:49 PM
wyoming9's Avatar
Smile
Have you checked with a multimeter if you are getting voltage to the socket when the lights are on??
I have seen sockets get corroded that you can`t see by looking at them cause this problem.
If this has the trailer light converter they sometimes good bad inside.
Look for pinched, cut , and wires damaged in any way
Old Jun 26, 2011 | 02:51 AM
greencactus3's Avatar
my housings came so corroded the wires were breaking off.
resoldered a new harness on and it works great now
Old Jun 28, 2011 | 03:12 PM
carcrazed484's Avatar
I would say the wiring but you said they were ok so that's wierd.
Old Jun 30, 2011 | 06:52 AM
4Crawler's Avatar
One bulb or all 3? Check the ground connection there near the light and also check that the connection inside the socket body is OK. You can't just look at it, you need a meter or test light to check that you are getting a good connection for power and ground. And any chance you have a trailer light wiring harness installed?
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
