Spark Plugs,Dual electrode or single, 3.4
My bro hooked me up with some NGK Irdium Spark plugs at dealer price of only $5 each instead of $12. But they are only single elctrode. Should I use them or go get double electrode plugs?
I would get the stock Denso Dual electrodes for 2$/each
Agree with Localmotion... unless you have a supercharger etc. you don't need to upgrade to those Iridium plugs. Just stay with the Denso/NGK dual electrode plugs and OEM plug wires and you're good to go.
If you've moded the engine i.e. cams, added a supercharger or moded other parts in the induction system, increased compression ratio or upgraded other parts of the ignition system i.e. blaster coil etc. then it makes sense to upgrade the wires if not.....stock is fine! Same for the plugs, if your running a stock motor...its a total waste of money to run anything more than stock!
word ... i would of went with stock denso wires but the stealer wanted 60 bucks..... and be very carefull with the clips on the coil that hold the sparks plugs i broke 2 of mine cost me 10 bucks for 2 new ones
Who know's what's next!
