General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
oil pressure readings
Old Oct 11, 2010 | 06:08 AM
ted's Avatar
ted
how are your stock toyota oil pressure gauge reading at idle? be it on a v6 or 4cyl
especially on those truck which had a sr5 gauge swap .
what are the signs if the oil pressure sending unit are defective?
Thanks
Old Oct 11, 2010 | 03:03 PM
myyota's Avatar
The stock oil presure gauge in our trucks arn`t very accurate, at warm idle on my 4Runner reads at about a quarter on the gauge and when driving it reads close to half on the gauge. If the sending unit is bad the gauge can read real low or not at all.
Old Oct 16, 2010 | 03:15 PM
ted's Avatar
ted
thanks myyota
Old Oct 16, 2010 | 05:24 PM
richf's Avatar
Does any one know the actual psi reading? I picked up a auto meter cause the sr5 gauge cluster I have doesn't work even with the new sender. I think I had something like 50 psi during my test hook up.
Old Oct 16, 2010 | 07:42 PM
wentz912's Avatar
I recall the FSM saying something like no less than 8 psi at idle, and greater than 45 psi at 2500 rpm. I could be way off though, it's been a long time since I've looked at that thing.
Old Oct 17, 2010 | 02:30 PM
ted's Avatar
ted
@richf
http://en.wikipedia.org/wiki/Oil_pum...bustion_engine)
I have a slight "nose bleed" reading this, but helped me a little to understand.... I plan to read it again and expects the same nose bleed but would be hoping to digest it even more.
Old Oct 25, 2010 | 01:12 PM
shower's Avatar
oil pressure problems
I have an 02 tundra with the 4.7 v8 recently the oil pressure was low at idle and while I was driving so I changed the sending unit nothing changed so I put in a manual gauge. Now on the manual gauge when cold at start up my oil pressure is between 75-80 PSI. When warm & driving about 55 mph. it is about 45 PSI. When I stop at idle its between 10 & 12 PSI. Does anyone know anything about this have any suggestions please let me know.
Old Oct 26, 2010 | 01:32 PM
cummins6speed's Avatar
Check the FSM, it will have the readings you are looking for
Old Oct 26, 2010 | 03:04 PM
874runnersr5's Avatar
You still got the autometer hooked up? mine is reading about the same, "70"psi when its cold out and just fired her up, after shes warm its 20psi at idle...
what is yours reading?
Old Oct 28, 2010 | 01:22 PM
richf's Avatar
My truck is down right now and I never checked the reading when it was warm. I'll let you know when I get it back up and running.
Old Oct 28, 2010 | 03:00 PM
sounds good, you using the autometer sender to? also running the adapter for the fittings?
Old Oct 28, 2010 | 03:07 PM
richf's Avatar
ya same setup.
Old Oct 28, 2010 | 03:10 PM
good stuff, im interested to see what ya getting.. i have a feeling 70psi on a cold start is a little high..
Old Oct 28, 2010 | 03:39 PM
richf's Avatar
I dont see how it could hurt anything
Old Oct 28, 2010 | 04:29 PM
TOYOTA 1's Avatar
50+ on cold start, 10 or so @ idle.
25k on home rebuilt 22re with GOOD parts.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Coreyr384
Jul 10, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
