General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No power to anything: 87 4Runner
Old Jun 29, 2013 | 09:15 AM
ryanhammond's Avatar
I was trying to start my 87 4runner and the battery seemed to run down, so i put my charger on it and set it to the jump start option. Well it turned over about four times then nothing the dash won't light up dome/door lights nothing will come on. Even the winch and radio that is direct wired to the battery won't work. My battery tester says it fully charged. I tried replacing the inline fuse still nothing. Any ideas out there?
Thanks,
Old Oct 13, 2013 | 08:12 PM
egillette87's Avatar
From: PNW, armpits of north Seattle... Lake Forest Park
Battery terminals tightened on? Free of corrosion? All the grounds the same?
Old Oct 13, 2013 | 09:23 PM
RAD4Runner's Avatar
Thanks,
Like egillette87 said ^^^
Also, your battery tester is a load tester and not just a volt meter, correct?
Battery connector may look clean outside but interface between post and connector may be not
Old Oct 14, 2013 | 05:18 AM
j2the-e's Avatar
I would imagine he fixed it after 4 months
Old Oct 14, 2013 | 01:12 PM
I did fix it. It was a bad ground cable. Thanks for all the help though.
Old Oct 14, 2013 | 01:14 PM
It was fixed. Thanks though bad ground cable.
Jun 1, 2021 01:51 PM
jon.r
Jul 11, 2015 03:34 PM
nick b
Jul 11, 2015 04:38 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
