No passenger hi or low beams.
I have an 88 xtra cab and the passenger side headlight kind of doesn't work. Hi beam does not work and when the low beam is on, the light turns on but it barely lights up. The driver side hi/low beams work fine. Fuses are fine. I plugged in another light and it does the same thing. Very dim low beam and no hi beam. Any ides? THANKS!
Yes! This yotatech community is an awesome place for knowledge and opinions on just about any problems or questions you might have. If I've ever run into a problem or need advice on something I always get it here. Glad I joined, thanks a lot guys!
RAD4Runner build thread has a link somewhere on a headlight harness that can be bought off of ebay for a fair price. The way Toyota did the electric on these is a poor way of doing it. I am eventually going to replace mine with one when I get to it.
In my opinion, these trucks were designed for the standard headlights and most of us put in Halogen headlights and I think that just puts a strain on the whole harness and especially the combo switch.
As far as electrical troubleshooting, I am weak in that area, but would suggest cleaning all contacts checking your grounds.
I purchased that kit before I had a Toyota to run 100/90 bulbs. This is a totally Taiwan produced harness and the wire size doesn't conform to the American AWG (American Wire Gauge) standard. Because I was unsure of the wire size used I cut one main power and ground end off to look at the actual thickness of the wire. I chose not to install it because it looked like the wire size falls at about 16 AWG and not any bigger. While that's ok for 55/60 watt bulbs and some HID's it's not so good with higher wattage bulbs. I don't think my 100/90 bulbs would have been real be real happy with that.
itzmywife's
Jul 25, 2015 04:55 PM
