new hella 4000s and no instructions
hi i just bought some hella 4000s and i didnt get any wiring instructions there are three wires? i unpluged my stock hellas and was planning on using the wiring that is already there, but there are only two wires?
yeah i did look at the hella site and couldnt find them, but i figured it out. the yellow wire doesnt need hooked up on my setup. i made a bracket and i got them on. they are sooooooooo bright. i took pictures and i will post them asap.
Gap, on a second gen version the ARB bar isnt nearly that tall and you dont have room.
My hella 500's are only like 6.5" tall and you only have like another 1" ...1.5" tops left.
a hella 4000 is like 9.5" tall! never fit under the top bar of a second gen ARB bar.
hmmm. I may have to find someplace local (4WP?) and see if they will let me test fit the actual light housings on the bumper.
Snap-on, how/with what did you drill out new holes in your bull bar? I dont have a winch yet but that may be a problem in the future. I may be able to stuff the lights in there but then a winch wouldnt fit in the housing.
Mike
Mike
I just marked the holes and drilled them with a hand drill. The stock light mounts on an ARB (like mine) are set way toward the back of the bumper virutally under the top bar.
With my mount locaiton they sit farther forward and not under the top bar, so it was easy to drill the holes.
I moved mine because i custom fit a ramsey winch that had an intergrated soloind pack(well not after i got done with it) into my bumper. (as you can see)
