General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Lightbar Questions from a wiring newbie
Old Apr 16, 2014 | 04:38 AM
jaretstuff's Avatar
I'm looking into putting a low pro lightbar on the top of my truck, and needed some input. The bar in question is a 40in Cree led lightbar and. Had some questions
Should I buy the wiring harness or is that a waste of money
Do I need to get a higher rated battery
What is a good way to mount it to my roof without drilling.
I have been to pirate, here and a couple of lightbar forums with no definite answer. I was wondering if my fellow yota lovers could point me in the right direction
Old Apr 16, 2014 | 05:53 AM
JasonYota's Avatar
It should have came with some sort of wiring harness if you bought it new.
Battery will be fine, if it's in good condition.
Seems like you would have to drill it to the roof, you might be able to find some good adhesive strips, that's a lot of money to be held on with glue IMO
Old Apr 16, 2014 | 06:00 AM
dropzone's Avatar
Fossilized
No drill mounting- get a gutter mounted light bar like the old school Carr mounts or have one made from some tube. If you don't have a gutter i have Guys have used Thule or Yakima racks before. .cheap option see craigslist for used stuff.
Wiring kit- easiest way if you don't know much about Ohm's Law.
You will need a relay, fused circuit and a switch anyway.
Old Apr 16, 2014 | 06:33 AM
jaretstuff's Avatar
Thanks for the input Jason and drop zone, much appreciated. I was also wondering if a lightbar would look ok of my truck. It's lifted but is stock besides the 33s, lift and fenderflare. Anyone good with photochop that could make me an image. I've tried but it never ends up looking good
Old Apr 16, 2014 | 06:37 AM
JasonYota's Avatar
Have someone hold it up there and stand back and look. Old school photoshop
Old Apr 16, 2014 | 06:46 AM
jaretstuff's Avatar
I have not ordered one yet.
Old Apr 16, 2014 | 06:54 AM
JasonYota's Avatar
Just looked at your build for pics. It's hard to tell how it will look, it's your truck though
Old Apr 16, 2014 | 06:56 AM
jaretstuff's Avatar
Yep on my t100, mounting will be hard, if worse comes to worse I will drill, I just would prefer not too
Old Apr 16, 2014 | 06:59 AM
jaretstuff's Avatar
I'm thinking if I mount it very far forward like where a sun visor will mount it will look ok
Old Apr 16, 2014 | 07:02 AM
jaretstuff's Avatar
Old Apr 16, 2014 | 09:10 PM
Discombobulated's Avatar
Are you set on the roof mount? The top of the bumper IMO would look way cleaner on your rig
Old Apr 16, 2014 | 10:12 PM
RAD4Runner's Avatar
Concur.
No glare from light reflecting off mist/fog.
Also simplifies wiring; Needs shorter wires (= less voltage drops) and no need to drill holes to run wires.
More low-key for a daily-driver.
Old Apr 17, 2014 | 03:38 AM
jaretstuff's Avatar
Thanks dincombobulated that would look really clean and I will look into that
Old Apr 17, 2014 | 09:44 PM
v_man's Avatar
LED's are pretty low draw amp wise compared to Halogen lights, so you should have no problem running it off your current alternator and battery set up . Do you know how many amps your alt. is putting out . You can calculate how many amps your light bar will draw here :
http://www.supercircuits.com/resourc...amps-converter
If it were me , I'd mount something right there on either side of your license plate , right in that lower grill area .
X2 fusing, relaying, and switching whatever u go with ...
the1998sr5
15
Jul 14, 2020 08:35 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
garagespace
Jul 9, 2015 08:37 AM
