General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Home made hot shot starter kit?
Old Jul 9, 2010 | 10:19 PM
87forunner's Avatar
Sorry, this topic has been beaten to death...
The kit is just a relay and some wires? I see people have made their
own, but I'm wiring handicapped. Is there a sticky with a good diagram?
I've tried the "no start..." one without success. Took apart the stock relay
and I still don't get it. TIA
Old Jul 9, 2010 | 11:34 PM
awsumfn's Avatar
I have the starter booster kits in stock. The kit comes with a relay, harness connector and instructions. Very easy to install! I'm running one on my 83 Yota. Send me a personal message and I see if I can help you out.
Old Jul 9, 2010 | 11:40 PM
RMA's Avatar
RMA
What the heck is a Hot shot starter kit .. never heard of that.
Old Jul 9, 2010 | 11:49 PM
awsumfn's Avatar
Basicly these booster relays makes sure your starter get a full 12 volts to the solinoid while cranking. Many times in the older vehicles resistence build wire in the wiring and the ignition swich can send a reduced voltage signal to the starter solinoid. These booster kit eliminate the voltage drop. Very easy to install and look very clean when installed properly. We have been selling them for years at my old repair shop.
Old Jul 10, 2010 | 05:30 AM
4Crawler's Avatar
I have a description of the wiring connections on the web page below:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Jul 14, 2010 | 08:00 AM
87forunner's Avatar
Hate threads with no ends so..
I put the stock starter back in (it was fine, but had a new Bosch to put in when the new long block went in).
Truck fired right up, and turns over much faster.
I don't even see the point in returning the Bosch with warantee since it won't be good either.
Old Jul 28, 2010 | 02:14 PM
golddog111's Avatar
i just got a painless wiring hot shot relay and im confused? i mounted it to the inside passenger fender.... http://tweetphoto.com/35444153 but the connecter to the silinoid dont match, do i cut the smaller wire and use the same connector? http://tweetphoto.com/35444255. . someone post pics with it already installed please
Old Jul 28, 2010 | 08:26 PM
4Crawler's Avatar
I've added more wiring information (and a link to the Hot Shot install manual) on the page below:
I just use 2 pair of these kind of connectors in the factory wire and on the two purple relay kit wires:
Old Aug 11, 2014 | 07:38 AM
daw4589's Avatar
Hello my name David.I own a 1983 Toyota pickup 22r. 5 speed.Please send me info on the hot shot starter kit.I am interested in installing one on my truck.
Old Aug 11, 2014 | 08:50 AM
4Crawler's Avatar
You can find information on the Painless Wiring kit:
- http://www.painlessperformance.com/w...hot+shot&sb=Go!
Old Oct 14, 2014 | 09:24 PM
stanz's Avatar
I made my own: https://www.yotatech.com/forums/f116...-relay-276825/
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
ZONAYODA
Jul 13, 2015 07:17 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Poncho0206
Jul 10, 2015 06:21 PM
