General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlights shut off randomly
Old Aug 31, 2007 | 11:51 PM
deserttoy84's Avatar
My friends 87 pickup started having a weird headlight problem. When he has his headlights on they will somtimes shut off for about 2-3 sec then turn back on. All the other lights stay on, just the headlights go out. Ive gone around and checked connections and grounds and it still does it. Any help would be appreciated.
Old Aug 31, 2007 | 11:54 PM
JnJ's Avatar
JnJ
I'm curious as well...my 86 has done that a few times
Old Sep 1, 2007 | 12:45 AM
stormin94's Avatar
Bad Relay??? Does an 86 even have relays? I'm a 2nd gen 4Runner guy, but I can offer you my 2 cents, since cars are SIMILAR, but not the same.
Old Sep 1, 2007 | 07:56 AM
4Crawler's Avatar
Likely the headlight/combo switch:
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Easy test is next time they go out, pull back on the combo switch and if the lights come on (flash mode) then the factory relay, fuses and wiring are fine. Flash mode uses separate contacts in the combo switch, so that is the only change between normal and flash mode.
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
JPV
Sep 28, 2015 03:15 PM
