General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlight Problem
Old Apr 16, 2007 | 12:50 PM
Belize Off Road Team's Avatar
that description is for a 1992+ Runner/Taco...the problem with the very first 2nd gens is that they where different in a few but major ways. like for example the wiring of the lights, and all that other kinda stuff. and the wiring digram from Toyota does not even show it unless you can really understand a diagram. thanks for the link though!
Old Apr 16, 2007 | 01:04 PM
4Crawler's Avatar
Read closer:
- http://www.4crawler.com/4x4/CheapTri...ghts.shtml#DRL
On the earlier model DRL systems (i.e early '90's Canadian vehices) there is a DRL relay box that controls the DRL functions. To disable the DRLs, you can cut the black w/ orange stripe wire in the DRL relay box, if desired. The headlights work in a switched power mode and will work with or without the DRL relay functioning.
Old Apr 20, 2007 | 01:30 PM
i did after i posted it and duh, but i tried it and nothing...still did not work...so i called Toyota and talk to the head mechanic and he said to cut and ground the Green w/ Yellow stripe, there for fouling the system into thinking the praking brake is on. I think it is different depending on when the Runner was made..what time of the year. because i cant figure it out and im not going to cut every wire to find it out. Thanks from the Belize Off Road Team!
ghostmoney
Jan 28, 2018 11:42 AM
Sep 4, 2015 09:27 AM
Jonny246
Jul 24, 2015 12:37 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
