General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
headlight
Old Jul 9, 2019 | 03:52 AM
Willy D's Avatar
headlight
2002 Toyota Tacoma drivers side headlight wire melted. I replaced the wire connector the light comes on but its not bright.
Old Jul 9, 2019 | 05:43 AM
dropzone's Avatar
Fossilized
Did you put in a high amp draw bulb? I use to run 130w H4 in my 84 truck. Bought a 97 Taco and swapped the bulbs over and immediately melted the wiring.
Had to rewire it back a ways in the loom. You might consider swapping your fuse.
Old Jul 10, 2019 | 10:01 AM
Willy D's Avatar
Thank you I replaced fuse and it bright again.
Old Jul 10, 2019 | 01:48 PM
old87yota's Avatar
I bet the light was dim because it was feeding power and/or ground off of the other headlight, as they are wired together.
Just make sure your wires have been repaired! See Dropzone's advice above if you are not running stock headlight bulbs.
bend
Oct 14, 2012 03:50 PM
Mossback74
11
Nov 4, 2010 03:29 PM
joshik
18
Feb 15, 2006 11:12 AM
Mustang351
Nov 25, 2002 07:56 PM
