General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
head unit not functioning
Old Jul 28, 2010 | 10:05 AM
tnevy4's Avatar
i was working on installing a sony head unit in a 1987 4runner and i got it hooked up and working with the front speakers. i took it out and started putting on splices for the rear speakers. when i reattached the cd player it would no longer power up the display or anything, but it will take a cd and eject it as well. any ideas or help is appreciated
Old Jul 29, 2010 | 07:54 AM
tnevy4's Avatar
bump for help all the wires are connected correctly and i have no clue what is going on all the fuses under the hood are fine and the fuse on the back of the head unit is fine too
Old Jul 29, 2010 | 10:28 AM
scottishb's Avatar
Sounds like constant power is still there. Check the ignition wire going to the head unit. The unit will still take CDs and eject them with the constant power attached.
Old Jul 29, 2010 | 10:33 AM
scottishb's Avatar
If you want, take a spare wire and run it from the positive on the battery and hook it directly to the yellow wire coming from the Sony. Or simply run a little jumper wire from the red wire to the yellow one and see if it turns on.
red: constant power
yellow: ignition
Old Jul 29, 2010 | 10:45 AM
tnevy4's Avatar
thank you very much good sir that worked like a charm, now i just have to figure out what is up with the ignition wire
Old Jul 29, 2010 | 10:51 AM
peow130's Avatar
Check your cigarette lighter, does it work?
IF NOT: Change your cigarette lighter fuse.
The head unit gets it's power through that fuse and loom of wire..
Old Jul 29, 2010 | 10:54 AM
tnevy4's Avatar
if you don't mind where would that particular fuse be located?
Old Jul 29, 2010 | 11:01 AM
tnevy4's Avatar
nevermind on the last question i had that kick panel off the other day and did not notice the fuse panel cover
Old Jul 29, 2010 | 01:57 PM
peow130's Avatar
Drivers side under kick panel..
The fuse is labelled "Cig"
or uhh...
"Acc"
I dont remember.
Just check if your cig lighter works lol
Old Jul 29, 2010 | 03:36 PM
tnevy4's Avatar
i got it fixed found the fuse replaced it then the player worked like a champ thanks for all your help guys
Old Jul 30, 2010 | 11:39 AM
peow130's Avatar
Yeah no problem.
I had the same issue with mine, too, after i was in an accident
Old Aug 2, 2010 | 04:57 PM
8yota9's Avatar
kinda off topic but can eney body point me in the right direction to a good ipod capable head unit and good speakers bigger than stock that will fit in the stock location in my 94 ex cab pickup. i belive i will need 4. ive never started a system from scratch but all the trucks speakers are blown and shes got the stock AM/FM radio. thanks for the help
Blamalam
Mar 12, 2022 07:34 AM
mussy01
Dec 13, 2016 08:20 PM
JAmdor3
Aug 11, 2015 10:53 AM
Odin
Jul 15, 2015 09:28 PM
icentropy
Jul 14, 2015 10:23 AM
