Gear Indicator Lights on 3rd Gen
On the dash or by the shifter itself? Both should light up, on my 00 Ltd the indicators by the shifter weren't lighting up, it's as simple as popping up the trim piece around it and replacing one tiny little bulb... not sure of the part # but if you take it to the parts counter at the stealership they'll have no problem taking your money.
aaah, gotta love 'search'
can someone give me a hint as to how to pop this piece off?
i've been searching around with a flashlight to find a starting point for the 'popping' but nothing looks obvious or wants to give without a hard yank...
i'm kinda wearing about just yanking at it unless i know its the right spot\
(said the actress to the bishop)
ta!
ta!
i'm not sure where to start prying tho...
there's a thing plastic plastic piece right over the gear indicators?
or the bigger piece surrounding the whole shifter?
maybe i'll just pop the whole console off and take a peek
hell, if you are close I'll give you a hand if you need.
https://www.yotatech.com/forums/f127...acement-70183/
after seeing that i remember how it looked when i installed the stereo...
on the 3rd pic down you can see the black plastic part that has the actual gear indicators on? i think i need to get that bit off
ok, so if you have good fingers then you do not need to remove anything further. slip your fingers under the shifter from the steering wheel side. In the middle area you will feel a wire coming up to a plastic piece with ridges. You can just twist that and pull down and the bulb and socket should come down. replace the bulb and do the same thing but reverse. have some patience and it should go smooth.
A little late, mind you this was dug up from 2009 as your first post, so really late.., but bulb #74 is incorrect for the PRND21 light, you need bulb #2721, just went through this, #74 is to long and bottoms out making it so you cannot lock it in position, (different suppliers may vary in bulb size slightly) and the base of the bulb is a bit to big but will jam into the socket and light up but not advisable.
Skizor1337
Apr 22, 2010 05:39 PM
Firebb15
Aug 11, 2009 12:19 PM
98SR54RUNNER
15
Jan 22, 2009 09:20 AM
