General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Dual Batt Isolator: what should the 'Exciter' terminal be hooked to?
Old Aug 25, 2010 | 11:13 AM
snickell's Avatar
I'm doing up a dual-battery setup on my '85 pickup. Got a marine deep cycle for the aux battery and have it setup nicely, now I just need to tackle the isolator.
I bought a Sure 9532A isolator w/ 4 terminals on the basis of their chart ("Toyota / Japanese Import w/ internal regulator on alt"). I'm a little mystified by the 'E' (aka "Exciter" I think) terminal. What should I hook that to? What is it for?
I've got a wiring harness coming off the alternator. Besides the fat-red main current wire off the alternator, my wiring harness includes a white wire, a yellow wire a black wire, and a thin red wire. Should I splice into one of these?
Thanks for any tips, Seth.
Old Aug 25, 2010 | 11:27 AM
j-money$$$'s Avatar
It hooks to one of the 3 wires that plug into the alternator. I forgot which one it is, green rings a bell as far as color. but please make sure!!!!!!!!!!!!!!!!!!!!!! dont cut something without being 100%. Search this forum for dual battery setup, i know i have a write up. and this question was asked by someone else in that thread, maybe you can pm them for the answer
Old Aug 25, 2010 | 05:59 PM
snickell's Avatar
Hey, thanks for the reply, as you said... isolators are a bit on the side of boring, so I appreciate it.
I think this is the thread you're referring to:
https://www.yotatech.com/forums/f2/d...talled-198973/
I've been hunting through the archives (and your thread of course), and I still haven't figured out which wire to attach to. The Sure Power instructions say the wire labelled "IGN", but unfortunately, my harness/alternator has no label. I've looked at the factory service manual, and again, no obvious help.
Anyone got a doc on this? Or anyone using a four post terminal willing to pop their hood and check which wire on their alternator harness is going to the exciter terminal?
Old Aug 25, 2010 | 07:16 PM
4Crawler's Avatar
Grab a volt meter or test light and find a wire. I think I used one off the alternator connector that turns on and off with the ignition. But there are lots of wires that do the same under the hood:
- http://www.4crawler.com/4x4/CheapTri...l#Installation
kawazx636
Oct 6, 2021 03:03 PM
Steven.m.paulk
Jun 7, 2020 10:45 AM
smilen724
13
Nov 8, 2015 04:11 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
