General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
DRLs
Old Oct 19, 2009 | 04:13 PM
JMorry's Avatar
DRLs
Hi All,
Need to install daytime running lights to make my American purchased
truck Canada-worthy.
I talked to a Toyota tech and he said for a '99 4runner it's a simple relay matter.
Any help would be much appreciated!
Old Oct 19, 2009 | 04:15 PM
theAuthority's Avatar
User Requested Ban
I just searched "daytime running lights" and found this
https://www.yotatech.com/forums/f131...ht-kit-189443/
Next time, try using it. Welcome to YotaTech btw.
Old Oct 19, 2009 | 04:25 PM
JMorry's Avatar
thanks theAuthority, I came across this thread.
Maybe I'm missing it, but if there's a response to Daman's last post, that would help me out a lot.
Old Oct 19, 2009 | 04:29 PM
User Requested Ban
Just find an FSM for your vehicle, you haven't really told us what your vehicle is.
Find the headlight wire that is activated by your headlight switch and run it to an accessory power wire. If you've ever hooked up a stereo it's usually the red wire, while the yellow wire is constant power.
So ANYTIME you turn your key to accessory or to start it, your headlights will turn on.
Old Oct 19, 2009 | 04:31 PM
JMorry's Avatar
my bad - 1999 4runner.
Old Oct 19, 2009 | 04:32 PM
User Requested Ban
Found this, since I last posted ... took me 3 minutes google->tundra forums -> 4 runner forums -> yotatech haha
https://www.yotatech.com/forums/f2/4...tml#post391085
Old Oct 19, 2009 | 04:38 PM
JMorry's Avatar
yup same one
Old Oct 19, 2009 | 04:41 PM
User Requested Ban
Ah crap I posted wrong one, forgot to copy and paste, give me 2 seconds
this is what I meant to post ..
Old Oct 19, 2009 | 04:46 PM
eric-the-red's Avatar
Originally Posted by JMorry
Hi All,
I have a used DRL relay from a 99 4Runner, it's yours if you want it. Don't know how easy it would be to install, maybe just plug it in or maybe some wiring would be needed. Or Canadian tire sells aftermarket kits for about $30
Old Oct 19, 2009 | 04:51 PM
JMorry's Avatar
if you believe it I've been searching for 2 hours - not as efficiently as you, apparently
thanks bud I'll give this a try
Old Oct 20, 2009 | 05:31 PM
JMorry's Avatar
That would be great Eric. you ever come into Van?
Old Oct 20, 2009 | 05:57 PM
Godzilla's Avatar
You will learn alot about the setup of DRL's for 3rd gen 4Runners by searching "fog light mod" as many have to deal with the DRL to allow for the independent use of the fog lights.
It is weird that some (US) model 4Runner in 99 had a DRL setup where others did not.
If yours did not it may be easier to just go and pick up the kit from Cambodian Tire.
https://www.yotatech.com/forums/f2/2...runner-150139/
https://www.yotatech.com/forums/f2/drl-help-17254/
http://www.top4runners.com/ja/fogmod.html
Old Oct 22, 2009 | 04:25 PM
I'm giving you the part free, I wasn't really planning on including delivery as well
Actually my wife works in Vancouver so we could probably work some thing out for next week. What part of the city are you in.
highplainsdrifter
Sep 9, 2007 05:56 PM
proscllc
Jan 15, 2007 02:11 PM
Corey
Aug 10, 2006 01:59 PM
Corey
Jun 8, 2006 02:18 AM
