General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Old Mar 11, 2016, 03:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
Battery not charging
Old Oct 24, 2006 | 05:31 PM
Thepilotone15's Avatar
This is my first post here, I would like to say hello to everyone. I have a 91 5speed manual 3.0 V6 Runner. Lately I have a problem; before I start the car the battery voltage is about 12 volts, and when I start it instead of being 14 it is still at 12. I really doubt that it is the alternator because of the symptoms. To begin with the brake light and the battery light in the dash go on and off simultaneously. When I start the car the voltage is at 12, and both the battery and the brake lights are on. Once I rev the engine to about 2000 RPM both of the lights go off, but the voltage stays 12. They lights will occasionally flicker on and off. This is the main reason why I believe this problem to be electrical and not mechanical. The car starts without a problem so its not the distributor or the started.
If anyone know anything that would be a great help, I can't drive until I get this fixed because my battery will die. Is it possible that it is a short somewhere in the alternator and brake light wire? Are they located in the same place?
Thanks in advance for your help.
Old Oct 24, 2006 | 07:18 PM
Firefightertaco's Avatar
I think its your alt. you can test it by starting your car and put a screwdriver near the center of the alt. pully and if it has a magnetic charge to it (it pulls the screwdriver in toward the pully like a magnet) then your alt. is creating a charge and it should be charging the battery, if its not pulling the screwdriver then its not charging and u need a new alt.
Old Oct 24, 2006 | 07:33 PM
4Crawler's Avatar
http://www.4x4wire.com/toyota/mainte...nator_brushes/
Old Oct 24, 2006 | 07:40 PM
Wow, thanks for your input, both of you, I hope you are wrong, but I fear you are right.
Old Nov 19, 2006 | 08:38 AM
toyota_mdt_tech's Avatar
Originally Posted by Thepilotone15
...I really doubt that it is the alternator because of the symptoms. To begin with the brake light and the battery light in the dash go on and off simultaneously....
That tells you it IS the alternator. !
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
Gone Fission
Oct 7, 2015 12:42 PM
mreagen
Oct 5, 2015 04:27 PM
bradahman
Oct 1, 2015 09:24 AM
