General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Back Up Lights on 1997 4Runner
Old Nov 7, 2007 | 03:43 PM
Zeroth's Avatar
Both of my back up lights are out in my 1997 4Runner. I checked the bulbs, and they are good. I checked the fuse locations, but I did not see any indications that any of the fuses are for the back up lights. Does anyone have any suggestions?
Old Nov 7, 2007 | 04:27 PM
rowdy235's Avatar
If automatic remove the shift cover and check that the connector is securely plugged in and test switch per instructions in manual.
If Stick, crawl underneath vehicle and check that all electrical connections going into the transmission are secure.
Hope this helps.
Old Nov 7, 2007 | 05:47 PM
eric-the-red's Avatar
On my 01 the back up lights are powered by the GUAGE fuse, it doesn't have a seperate one just for the lights. I would think all 3rd gens are the same. Check that fuse, and if the bulbs are OK it's probably the switch.
Old Nov 7, 2007 | 08:40 PM
Albuquerque Jim's Avatar
I have replaced the switch on mine. It's located on the pass. side of the Trans (5-speed).
Old Nov 7, 2007 | 08:42 PM
Jay351's Avatar
start checking connectors and wires. Make sure you are getting current to your rear lights. Do you have a trailor hookup?
Old Nov 8, 2007 | 09:16 AM
Zeroth's Avatar
Thanks. I will try that.
Old Nov 8, 2007 | 09:18 AM
Zeroth's Avatar
I have no trailer hook up. I will check the wires. Thanks.
Old Nov 8, 2007 | 09:20 AM
Zeroth's Avatar
I will check the Gauge fuse.
arlindsay1992
Jan 23, 2024 01:34 PM
gillesdetrail
Nov 19, 2019 12:56 PM
aciorba23
Jun 29, 2015 04:18 PM
infinityisfive
Jun 16, 2015 06:51 PM
