98 tacoma power window
Just finished fixing my driver's side power window on my 98 Tacoma. A couple of days ago it quit working. Last night I found that the wires that power the lift motor had pulled out of their connector shell due to NO SLACK AT ALL. Seemed kind of weird, so I assumed that someone had been in there in the past and mis-mounted some clip-in-a-hole connector somewhere.
Today I discovered that a couple of the bolts holding the regulator/motor/lift ass'y. to the door had worked their way out. Thus when power was applied to the motor it spent part of its work pulling away from the connector instead of raising and lowering the window. Replaced bolts and AHA! problem solved.
Now I need to replace the plastic rain shield sheeting but I'm lazy so put it all back together minus the sheeting for now. Besides, Wyoming is a pretty dry climate. Shouldn't rain again here until next Spring. Plenty of time to forget to do that chore. <8-0
banjodan in Wyo.
banjodan in Wyo.
Jun 1, 2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
