General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
96 SR5 4Runner missing fuel pump power......
Old Apr 8, 2018 | 06:54 PM
JeromeFuller's Avatar
Hello all, I'm still new at this Toyota thing but here it goes. I posted yesterday about a possible sending unit issue. I'm pretty sure I nailed down the sending issue being the actual sender. Another member was able to point me to the sender harness where I measured 15ohms but pretty sure the tank is 3/4 full even though the gauge displays anywhere from total empty to 1/2 full. It changes while i drive. I was satisfied I had that figured out so I plugged the harness back in and tried to start the truck. It would crank strong but not fire. I pulled the harness back off and now discovered I did not have 12v on the fuel pump wiring and I definately had it while testing resistance on the sender. Now I had 125ohms on the sender and the dash gauge matched that. I could only find info that suggested pulling the efi relay under the hood, which I did and that "fixed" the issue..... or so I thought. I left the truck and went back about 4hrs later only to have the same issue again but this time I was unable to get the truck started. I wanted to take it to the gas station to top it all the way off and check sending resistance again but it would not start. It was getting dark so I just left it alone for the night. Will get back to it tomorrow. I cannot find any fuses labeled FUEL PUMP. If anyone could point me in the correct direction I'd greatly appreciate it. I can feel the relay clicking with the key in the on position and I pull out the relay but I don't know for sure if it's opening or closing. Thanks again everyone, Jerome
Shawnjames
Jul 24, 2013 10:08 PM
komh98
May 3, 2009 06:18 PM
flamingdove
Feb 20, 2008 07:22 PM
MikeKaduce
Nov 6, 2006 06:21 PM
