86 EFI Turbo computer problems
I recently obtained a 1986 Toyota EFI Turbo 4x4 (the truck worked fine when last parked). It had been sitting for a little over a year and a rat had done some minor damage to the wiring. After re-connecting all the wires the electonics seem to work and the engine turns over but the fuel pump will not work. I checked the pump and its good. I also noticed the check engine light does not turn on. The local toyota tech is saying it a computer problem. Does anyone have any insight on this before i throw down the 500$ on a new computer? Thanks -Steve
500 for a new one......heck i have an 86 turbo ecu that i will sell for $100 plus shipping...e-mail me if you want it. dnogle@ivytech.edu
Also wondering if anyone could tell me where the ground wire coming from the passenger side of the engine block(parraleling the main battery ground) goes to. I think this might be my problem but i cant seem to find where it connects to.
not sure if you are familiar with this site, http://www.22rte-trucks.com/simplema...orum/index.php but it is a great resource for 22RET trucks
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
I know this is an old thread but the ground goes to the intake lower stud and it grounds the ecu so if not hooked up it will not pulse the injectors anyway hope it was fixed before now but if not that should help no need to buy a new ecu
Easy enough to make the fuel pump run:
