General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1st gen tacoma electrical issues
Old Feb 8, 2014 | 07:07 AM
chickenhammer's Avatar
I was driving home from work yesterday and I hit a pothole that I didn't see in time, a few seconds after that my fan blower, Speedo, tach, and temp gauge all quit working at the same time, fuel gauge works just fine, everything is plugged in to the back of the instrument panel, truck still runs good, starts up and drives fantastic
Old Feb 8, 2014 | 11:37 PM
Terrys87's Avatar
I had a similar issue. Here is how I fixed mine. Is your ENG fuse blown?
FIXED!!! Mine was the Reverse Lights on the Tranny. It has a protective sleeve and depending on how the sleeve slides, it can cover the wires where they rub against the tranny leaving them exposed. Below is other fixes for this problem.
Old Feb 8, 2014 | 11:53 PM
RAD4Runner's Avatar
A possibility if "fan blower, Speedo, tach, and temp gauge" share the ENG fuse. Gotta look at schematic.
However, regardless of what O.P. finds out, I highly recommend inspecting that because wiring to back-up light switch is poorly routed and design could be better (switched ground would make it safer), as shown here.
Old Feb 9, 2014 | 12:04 AM
Terrys87's Avatar
I will need to make sure it is the ENG fuse. I know when I fixed mine, they all shared the same fuse. It kept shorting out and all the same fuse. There are several other things on that circuit as well. I think he will find he has a blown fuse. It will be in the drivers side kick panel in the cab.
Old Feb 9, 2014 | 08:27 AM
RAD4Runner's Avatar
chickenhammer,
Mind posting schematic of your truck? The part that shows all "fan blower, Speedo, tach, and temp gauge"
Old Feb 9, 2014 | 12:39 PM
wyoming9's Avatar
Red face
Schematic??
Pray tell just what is that??
On my 2000 what he lost is all powered by the 10 amp gauge fuse as well as the back up lights.
Go figure!!
Old Feb 9, 2014 | 12:43 PM
So I went and got the fuse and all the gauges work now but the blinkers do not come on now, the bulbs are good and everything is plugged in, is there something um missing
Old Feb 9, 2014 | 12:54 PM
wyoming9's Avatar
Red face
Do they not come on at all??
Do they light but not Flash?/
Do the Hazard lights work??
Did you bump something like the flasher changing the fuse??
Old Feb 9, 2014 | 01:20 PM
Yes they light up but don't flash, hazards don't work either
Old Feb 9, 2014 | 04:25 PM
RAD4Runner's Avatar
Yep, we're missing a schematic.
Old Feb 9, 2014 | 05:17 PM
Ok solved the blinker problem, still don't know what it was I took the little box apart thatvthe lever is connected to and put it back together and it works now, thanks everyone
sandyota
Feb 4, 2021 11:16 AM
coryc85
Sep 9, 2015 06:24 AM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
coryc85
Jul 6, 2015 04:07 AM
