General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1986 02 Sensor Shielding question
Old Jul 11, 2023 | 07:16 AM
pimacdaddy's Avatar
so I always sucked at electrical wiring and splicing
but never too late to learn. I know that the signal wire inside the black sheating cant be mixed with the shielding wire over it but where do the shielding connect to at the yellow round plug ??
Old Jul 11, 2023 | 07:47 AM
4Crawler's Avatar
It doesn't hook to the connector. The early 22REs have a 1-wire O2 sensor connector for the signal and the manifold is the ground connection. The shield is grounded where that wire originates but not at the O2 sensor itself.
Old Jul 11, 2023 | 07:49 AM
pimacdaddy's Avatar
Ok great. So I still crimp the shielding together for my splicing though
Old Jul 16, 2023 | 08:17 AM
4Crawler's Avatar
Yes, if you're extending the cable, it would be a good idea to extend the shield as well.
Old Jul 19, 2023 | 05:02 PM
2ToyGuy's Avatar
Bear in mind that the nice thing about shielding like that is that it only needs be connected to ground at one end or the other. You don't need a complete circuit for shielding. You just need to make the insulation of the signal wire to be at ground potential, so just one end, to drain the noise it picks up, off to ground. The more insulation that stays covered is important, though. The less that's covered in shielding is the more to allow noise into the circuit.
Many many years as a lead Radar Tech for an Aerostat (look it up: big, fat, balloon), not to mention being an F-4 Phantom II radar tech, gives you a lot of little tips and tricks.
Good fortune to ya!
Pat☺
Old Jul 21, 2023 | 04:23 PM
pimacdaddy's Avatar
Good fortune to ya!
Pat☺
Ok so if my ende look like that this; thats fine ?
Old Jul 22, 2023 | 11:16 AM
2ToyGuy's Avatar
As long as the shield is grounded at some point, an end, the middle, 1/3 of way along, somewhere, you're in good shape.
And yes, the shield is close enough to the end to function very nicely
Pat☺
Old Jul 22, 2023 | 03:30 PM
pimacdaddy's Avatar
Well I keep getting code 5 on my 22RTE... Changed the 02 sensor code came back. Test for ground continuity at the 0x wire, spliced it 3 times now about to buy this kit along with a crimping ratchet tool....
jdurango
Mar 23, 2023 07:46 AM
Boogeyman
Jan 21, 2022 03:48 PM
dezrik
Oct 6, 2015 11:45 AM
BajaToy616
Feb 28, 2012 09:23 AM
